- To: Andrej Bauer <andrej.bauer AT andrej.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Does Coq actively convert things to Prop?
- Date: Wed, 18 Apr 2012 15:31:30 +0200
Le 18/04/2012 13:36, Andrej Bauer a écrit :
> I am not proposing an incompatibility change, I think. I am proposing
> that the type should be honored when explicitly given. Because I
> explicitly defined that Q should map to Type, it should map to Type.
> If I asked Coq to _infer_ the type and it decided it was Prop, then I
> would have no objection. But as far as I am concerned this is a bug.
This is not a bug for me, merely an unfortunate convention.
"Type" in this position means "infer", whereas most of the time it means
"a new universe". As far as I know, there is no syntax for "a new
universe" in this position. The "infer" semantics is needed for universe
polymorphism.
If you want "a new universe", you can (as you've figured out) define a
constant to be "Type" (which will effectively create a new universe),
and use that constant. Yes, it will fix the level, but I don't see how
you can avoid that: inductive types can be polymorphic only in the types
of parameters, not the return sort.
Cheers,
Stéphane
- Re: [Coq-Club] Does Coq actively convert things to Prop?, (continued)
Arnaud Spiwack
Andrej Bauer
Bernard Hurley
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Andrej Bauer
- Re: [Coq-Club] Does Coq actively convert things to Prop?, AUGER Cédric
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Frederic Blanqui
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Pierre Courtieu
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Bernard Hurley
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Randy Pollack
Bernard Hurley
Andrej Bauer
Arnaud Spiwack
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Frédéric Tuong
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Michael Shulman
