coq-club - Re: [Coq-Club] Does Coq actively convert things to Prop?
chronological Thread
  • To: Bernard Hurley <bernard AT marcade.biz>
  • Cc: Andrej Bauer <andrej.bauer AT andrej.com>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Does Coq actively convert things to Prop?
  • Date: Thu, 19 Apr 2012 13:59:39 -0400
Discussion of universes turns up regularly on this list.  I have
nothing new to add, but maybe not everyone on this thread understands
the situation in Coq:
Unless things have changed recently, Coq does not have full "universe
polymorphism".  E.g. merely duplicating a definition (thus allowing
more opportunity for choosing fresh universes) can extend what Coq
will accept as correctly stratified.  Coq is ad hoc in this respect.
I guess the reason for this is efficiency.
LEGO had features like "Type" (indeterminate, floating, as in Coq),
"Type(3)", "Type(alpha)"  (named universe levels; every occurrence is
given the same but indeterminate level) and "Type(alpha+3)".  LEGO had
a switch to turn on full universe polymorphism (but a naive
implementation), and indeed using that option made the system too slow
to use in practice.  Lego had a slightly different universe system
(Luo's Extended Calculus of Constructions) than Coq does.  Lego also
had a switch to turn off universe checking all together: Type-in-Type,
\lambda^*.
Randy
On Thu, Apr 19, 2012 at 5:34 AM, Bernard Hurley
 wrote:
> On Thu, Apr 19, 2012 at 07:18:58AM +0200, Andrej Bauer wrote:
>> First, casting to "Type" is not a type annotation because Type is not
>> a type...
> First could I say that I've found reading this thread very useful in
> understanding the Type heirarchy. (Yes, I know it's in the docs!)
> It does strike me, however, that someone might want to define something to
> be at a particular place, e.g. Type(3) or above.
> Regards,
> Bernard.
