- To: coq-club AT inria.fr
- Subject: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?
- Date: Mon, 23 Jul 2012 10:26:43 -0400
Dear Coq users,
not really knowing Coq, and being spoilt by Agda myself,
I am still trying to help somebody here with their Coq developments.
For practical purposes, the immediate problem seems to be solved
by using a different definition of IsSome:
Definition IsSome {T : Type} (x : option T) : Prop :=
match x with
| None => False
| Some _ => True
end.
However, I am still puzzled why I wasn't able to define IsSome_extract
starting from the inductive definition:
Inductive IsSome {T : Type} : option T -> Prop :=
| isSome : forall (r : T), IsSome (Some r).
This definition is used throughout in the remainder of this message.
I want to have IsSome_extract, and try:
Definition IsSome_extract : forall {A : Type} {x : option A} (xS : IsSome x)
, A :=
fun {A : Type} {x : option A} (xS : IsSome x) => match x with
| None => match xS return A with
end
| Some a => a
end.
Coq says:
| Error: Found a matching with no clauses on a term unknown to have an empty
| inductive type.
(Agda would know that IsSome None is an empty type...)
So I try a tactical ``proof'' instead of a term:
Lemma IsSome_extract : forall {A : Type} {x : option A} (xS : IsSome x) , A.
Proof.
intros.
induction x.
(* Case 1 *)
exact a.
(* Case 2 *)
Now I am in the 1-goal proof state:
A : Type
xS : IsSome None
A
and cannot find anything to continue --- at least
destruct, induction, inversion all complain about a sort issue,
and I didn't find anything else that looked possibly useful.
But ``obviously'', there can be no such xS!
How do I make Coq see this?
I found False_rect in CoqArt, and tried:
Definition IsSome_None_rect : forall T : Type , IsSome None -> T :=
fun (T : Type) (x : IsSome None) => match x return T with
end.
This also gets:
| inductive type.
Is there a way out?
Puzzled,
Wolfram
- [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Wolfram Kahl, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Adam Chlipala, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, gallais @ ensl.org, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Wolfram Kahl, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Paolo Herms, 07/23/2012
