coq-club - Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?
  • To: coq-club AT inria.fr
  • Cc: Adam Chlipala <adamc AT csail.mit.edu>, "gallais @ ensl.org" <guillaume.allais AT ens-lyon.org>
  • Subject: Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?
  • Date: Mon, 23 Jul 2012 11:43:07 -0400
Adam and Guillaume,
thanks a lot for your comprehensive and helpful answers!
To my problems with definining IsSome_extract for
>> Inductive IsSome {T : Type} : option T -> Prop :=
>> | isSome : forall (r : T), IsSome (Some r).
, Adam Chlipala wrote:
> OK, so here's my second attempt at a full answer: The phenomenon above
> is indeed what's going wrong in your example, though it (I now see) does
> not rule out writing a nice computational definition of
> [IsSome_extract]. You just need to express your contradiction solely
> within [Prop], and then you can do case analysis on a proof of [False],
> which is allowed because the universe restriction on [match] is waived
> for inductive types with at most one constructor, satisfying certain
> constraints. (This is how [False_rect] is defined, and I think that
> writing the [match] directly is clearer.)
> Lemma IsSome_None : forall {T}, IsSome (T := T) None -> False.
> inversion 1.
> Qed.
> Definition IsSome_extract {A : Type} {x : option A} : IsSome x -> A :=
> match x with
> | Some x => fun _ => x
> | None => fun H => match IsSome_None H with end
> end.
So the empty match works for False, but not for IsSome None
(which does have at most one constructor...) ---
are there useful cases besides False where it works,
or do the ``certain constraints'' effectively force us
to normally go via False?
``gallais'' wrote:
> Lemma IsSome_extract : forall A (x : option A), IsSome x -> { r | x = Some
> r }.
> Proof.
> intros A x Hx ; destruct x.
> exists a ; reflexivity.
> apply False_rect.
> inversion Hx.
> Qed.
(That additional equation is indeed essential, and I also had produced
it for the other definition in the meantime.)
I found it surprising that ``inversion Hx'' works here,
while in my attempt (without the False_rect of gallais),
it produces a sort error:
Lemma IsSome0_extract0 : forall {A : Type} {x : option A} (xS : IsSome0 x) ,
A.
Proof.
intros A x Hx.
induction x.
(* Case 1 *)
exact a.
(* Case 2 *)
inversion Hx.
| Toplevel input, characters 0-12:
| Error: Inversion would require case analysis on sort
| Type which is not allowed for inductive definition IsSome0.
I guess this is connected to the fact that in gallais' version,
inversion is used in a backwards-reasoning way, establishing the
current goal --- is there a way to use inversion (or something like it)
in a forwards-reasoning way in the proof state like the one here?
A : Type
Hx : IsSome None
A
Thanks a lot again!
Wolfram
