- To: Wolfram Kahl <kahl AT cas.mcmaster.ca>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?
- Date: Mon, 23 Jul 2012 10:43:43 -0400
On 07/23/2012 10:35 AM, Adam Chlipala wrote:
On 07/23/2012 10:26 AM, Wolfram Kahl wrote:
However, I am still puzzled why I wasn't able to define IsSome_extract
starting from the inductive definition:
Inductive IsSome {T : Type} : option T -> Prop :=
| isSome : forall (r : T), IsSome (Some r).
This definition is used throughout in the remainder of this message.
I want to have IsSome_extract, and try:
Definition IsSome_extract : forall {A : Type} {x : option A} (xS : IsSome x) , A :=
fun {A : Type} {x : option A} (xS : IsSome x) => match x with
| None => match xS return A with
end
| Some a => a
end.
It's a good thing that Coq rejects this definition, since _any_ definition of [IsSome_extract] would be breaking basic rules about what [Prop] means, and could even lead to logical inconsistency! ;)
A type in [Prop] is meant to have no computational content, and yet here you are trying to extract a potentially computational value out of one of these.
OK, so here's my second attempt at a full answer: The phenomenon above is indeed what's going wrong in your example, though it (I now see) does not rule out writing a nice computational definition of [IsSome_extract]. You just need to express your contradiction solely within [Prop], and then you can do case analysis on a proof of [False], which is allowed because the universe restriction on [match] is waived for inductive types with at most one constructor, satisfying certain constraints. (This is how [False_rect] is defined, and I think that writing the [match] directly is clearer.)
Lemma IsSome_None : forall {T}, IsSome (T := T) None -> False.
inversion 1.
Qed.
Definition IsSome_extract {A : Type} {x : option A} : IsSome x -> A :=
match x with
| Some x => fun _ => x
| None => fun H => match IsSome_None H with end
end.
- [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Wolfram Kahl, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Adam Chlipala, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, gallais @ ensl.org, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Wolfram Kahl, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Paolo Herms, 07/23/2012
