- To: Wolfram Kahl <kahl AT cas.mcmaster.ca>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?
- Date: Mon, 23 Jul 2012 11:56:59 -0400
On 07/23/2012 11:43 AM, Wolfram Kahl wrote:
``gallais'' wrote:
> Lemma IsSome_extract : forall A (x : option A), IsSome x -> { r | x =
Some r }.
> Proof.
> intros A x Hx ; destruct x.
> exists a ; reflexivity.
> apply False_rect.
> inversion Hx.
> Qed.
(That additional equation is indeed essential, and I also had produced
it for the other definition in the meantime.)
I found it surprising that ``inversion Hx'' works here,
while in my attempt (without the False_rect of gallais),
it produces a sort error.
The key is that he first applied [False_rect] to move into [Prop]. (This is exactly the Curry-Howard analogue of my advice.)
P.S.: I really advise _not_ using tactics to build dependently typed definitions with computational content.
- [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Wolfram Kahl, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Adam Chlipala, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, gallais @ ensl.org, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Wolfram Kahl, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Paolo Herms, 07/23/2012
