- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?
- Date: Mon, 23 Jul 2012 18:33:07 +0200
On Monday 23 July 2012 17:57:34 Adam Chlipala wrote:
> I really advise not using tactics to build dependently typed
> definitions with computational content.
I don't agree in this. If you carefully program your tactics, then they can
be
guided by the dependent type to be produced.
For instance, in Wolfram's example [a] is the only value that will allow to
prove the output type.
In bigger examples, where the tactics could produce more than one instance,
you could terminate the proof with [Defined] and then show some properties
about the definition, like minimality or whatever.
So quite the contrary: Dependently typed definitions are precisely the only
ones with computational content you could build using tactics.
I think tactics can be powerful and certified code generators.
Paolo Herms
PhD Student - CEA Software Safety Lab. / Inria ProVal project-team
Paris, France
- [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Wolfram Kahl, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Adam Chlipala, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, gallais @ ensl.org, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Wolfram Kahl, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Paolo Herms, 07/23/2012
