coq-club - Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?
  • From: "gallais @ ensl.org" <guillaume.allais AT ens-lyon.org>
  • To: Wolfram Kahl <kahl AT cas.mcmaster.ca>
  • Cc: Adam Chlipala <adamc AT csail.mit.edu>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?
  • Date: Mon, 23 Jul 2012 17:28:24 +0100
"move into Prop" refers to moving away from a goal [A]
(or [{ r | Some x = r}] in my example) which is in Type to
a goal in Prop ([False]).
There are a few cases where elimination of something
in Prop when trying to build something in Type is allowed:
http://coq.inria.fr/doc/Reference-Manual006.html#singleton
Basically when what you get from this elimination is:
- still in Prop and there's only one case (e.g. accessibility
predicates to define something by well-founded induction)
- nothing (because there are no constructors at all for this
proposition)
gallais
On 23 July 2012 17:06, Wolfram Kahl
wrote:
> Still in the context of:
> >> Inductive IsSome {T : Type} : option T -> Prop :=
> >> | isSome : forall (r : T), IsSome (Some r).
> , on Mon, Jul 23, 2012 at 11:56:59AM -0400, Adam Chlipala wrote:
> > On 07/23/2012 11:43 AM, Wolfram Kahl wrote:
> > >``gallais'' wrote:
> > > > Lemma IsSome_extract : forall A (x : option A), IsSome x -> { r |
> x
> > > = Some r }.
> > > > Proof.
> > > > intros A x Hx ; destruct x.
> > > > exists a ; reflexivity.
> > > > apply False_rect.
> > > > inversion Hx.
> > > > Qed.
> > >(That additional equation is indeed essential, and I also had produced
> > > it for the other definition in the meantime.)
> > >I found it surprising that ``inversion Hx'' works here,
> > >while in my attempt (without the False_rect of gallais),
> > >it produces a sort error.
> > The key is that he first applied [False_rect] to move into [Prop].
> Since [IsSome None : Prop] I am puzzled; what does ``move into [Prop]''
> mean here?
>> (This is exactly the Curry-Howard analogue of my advice.)
> Does this mean that [False_rect] is the only proof term constructor
> that eliminates empty [Prop]s?
>> P.S.: I really advise _not_ using tactics to build dependently typed
>> definitions with computational content.
> I know, and I didn't really want to do it either,
> but I thought I stood a better chance there
> since my ``obviously empty'' match was not accepted...
> Thanks again,
> Wolfram
