coq-club - Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?
  • From: "gallais @ ensl.org" <guillaume.allais AT ens-lyon.org>
  • To: Adam Chlipala <adamc AT csail.mit.edu>
  • Cc: Wolfram Kahl <kahl AT cas.mcmaster.ca>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?
  • Date: Mon, 23 Jul 2012 15:45:38 +0100
Hu?
Lemma IsSome_extract : forall A (x : option A), IsSome x -> { r | x = Some r
Proof.
intros A x Hx ; destruct x.
exists a ; reflexivity.
apply False_rect.
inversion Hx.
Qed.
gallais
On 23 July 2012 15:35, Adam Chlipala
wrote:
> On 07/23/2012 10:26 AM, Wolfram Kahl wrote:
>> However, I am still puzzled why I wasn't able to define IsSome_extract
>> starting from the inductive definition:
>> Inductive IsSome {T : Type} : option T -> Prop :=
>> | isSome : forall (r : T), IsSome (Some r).
>> This definition is used throughout in the remainder of this message.
>> I want to have IsSome_extract, and try:
>> Definition IsSome_extract : forall {A : Type} {x : option A} (xS :
>> IsSome x) , A :=
>> fun {A : Type} {x : option A} (xS : IsSome x) => match x with
>> | None => match xS return A with
>> end
>> | Some a => a
>> end.
> It's a good thing that Coq rejects this definition, since _any_ definition
> of [IsSome_extract] would be breaking basic rules about what [Prop] means,
> and could even lead to logical inconsistency! ;)
> A type in [Prop] is meant to have no computational content, and yet here you
> are trying to extract a potentially computational value out of one of these.
> Putting the definition in [Type] instead, everything goes through quite
> naturally. I don't know why you're proceeding by case analysis on [x]
> instead of [xS], which is much more direct.
> Inductive IsSome {T : Type} : option T -> Type :=
> Definition IsSome_extract {A : Type} {x : option A} (xS : IsSome x) : A :=
> let (v) := xS in v.
