- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?
- Date: Mon, 23 Jul 2012 13:05:55 -0400
On 07/23/2012 12:33 PM, Paolo Herms wrote:
On Monday 23 July 2012 17:57:34 Adam Chlipala wrote:
I really advise not using tactics to build dependently typedI don't agree in this.
definitions with computational content.
Yes, I know many people disagree. :-)
I just wanted to point out that tactics are not the "uncontroversial right way" for writing functions with complex types. I think direct Gallina programming leads to more readable and maintainable code in many cases, and it is worth learning the language features and tricks that enable such programming.
If you carefully program your tactics, then they can be
guided by the dependent type to be produced.
For instance, in Wolfram's example [a] is the only value that will allow to
prove the output type.
In bigger examples, where the tactics could produce more than one instance,
you could terminate the proof with [Defined] and then show some properties
about the definition, like minimality or whatever.
So quite the contrary: Dependently typed definitions are precisely the only
ones with computational content you could build using tactics.
I think tactics can be powerful and certified code generators.
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, (continued)
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Adam Chlipala, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, gallais @ ensl.org, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Wolfram Kahl, 07/23/2012
- Re: [Coq-Club] How to make Coq ``see'' emptyness of inductively defined Props?, Paolo Herms, 07/23/2012
