coq-club - Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
  • To: Vladimir Voevodsky <vladimir AT ias.edu>, Andrej Bauer <andrej.bauer AT andrej.com>
  • Cc: Bruno Barras <bruno.barras AT inria.fr>, Cody Roux <cody.roux AT andrew.cmu.edu>, coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>, "homotopytypetheory AT googlegroups.com" <homotopytypetheory AT googlegroups.com>
  • Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • Date: Thu, 09 Jan 2014 10:18:44 +0100
In fact, for this definition, you need no big ordinals. Iteration up to the first infinite ordinal \omega (i.e. on natural numbers) is enough to construct the semantics of [le]. But for types having constructors taking functions as arguments, it is necessary to use transfinite ordinals. For instance, with:
Inductive ord : Type :=
| Z : ord
| S : ord -> ord
| L : (nat -> ord) -> ord.
The term (L f) where f is the injection of nat into ord has size (in the models used in size-base termination) \omega+1.
Frédéric.
Le 09/01/2014 00:31, Vladimir Voevodsky a écrit :
On Jan 8, 2014, at 5:19 PM, Andrej Bauer
wrote:
It would
seem sensible to me to go the same route with inductive definitions,
namely, rely on semantic justifications rather than syntactic ones.
This would certainly be cool. What I do not quite understand however is what ordinals
or well-founded relations have with such inductive definition as, for example, the
definition of "less or equal" on nat in the Coq standard library?
(It's something like:
Inductive le : forall ( n m : nat ) , Type := le_refl : forall ( n : nat ) , le
n n | le_succ : forall ( n m : nat ) , le n m -> le (S n ) ( S m ) .
V.
