Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- To: Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: Andrej Bauer <andrej.bauer AT andrej.com>, Coq Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>, Cody Roux <cody.roux AT andrew.cmu.edu>, "homotopytypetheory AT googlegroups.com" <homotopytypetheory AT googlegroups.com>
- Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Thu, 9 Jan 2014 01:02:11 +0100
On 9 janv. 2014, at 00:41, Vladimir Voevodsky
wrote:
> On Jan 8, 2014, at 6:39 PM, Matthieu Sozeau
> wrote:
>> Well, take the transitive closure of p <_le le_succ n m p.
>> — Matthieu
> What is "p <_le le_succ n m p." ?
I guess that was a bit short indeed :) Here are the details. I’m using
packing with sigmas as it’s simpler to define the transitive closure
once and for all for homogeneous relations, there might be a more clever
way avoiding this:
I’m using Coq’s le in Prop, so I can’t prove wellfoundedness (this would
contradict the proof-irrelevance principle that Coq enforces). But with
everything in Set the proof would go through.
Require Import Relation_Definitions.
Require Import Relation_Operators.
Require Import Transitive_Closure.
Scheme le_dep := Induction for le Sort Prop.
(* That's <_le *)
Inductive le_le : forall {n m n' m' : nat}, le n m -> le n' m' -> Prop :=
le_le_S : forall n m (p : le n m), le_le p (le_S _ _ p).
Definition relation A := A -> A -> Prop.
Definition le_hom : relation {n : nat & { m : nat & le n m }} :=
fun x y =>
let 'existT n (existT m p) := x in
let 'existT n' (existT m' p') := y in
le_le p p'.
Definition le_rel : relation {n : nat & { m : nat & le n m }} :=
clos_trans _ le_hom.
Require Import Program.
Goal forall x, Acc le_rel x.
Proof.
intros x. apply Acc_clos_trans.
destruct x as [n [m p]].
simpl. induction p using le_dep. constructor.
intros [n' [m' p']]. simpl.
intros. (* inversion H does not close this branch as we are in Prop and
le_n can't be
discriminated from le_S *) admit.
constructor.
intros.
(* inversion H fails again as we are in Prop, but we should now that
n = n', m = m' and p = p' and apply the induction hypothesis *)
admit.
Qed.
Now you can (virtually, if you redo this in Set) make a “mathematical"
induction
on derivations of [le], you just need to pack/curry the derivation with its
indices
and apply the well-founded induction principle using the above proof.
— Matthieu
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, (continued)
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Jean Goubault-Larrecq, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Bruno Barras, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andrej Bauer, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Maxime Dénès, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/07/2014
