Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- To: Bruno Barras <bruno.barras AT inria.fr>
- Cc: Vladimir Voevodsky <vladimir AT ias.edu>, Cody Roux <cody.roux AT andrew.cmu.edu>, coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>, "homotopytypetheory AT googlegroups.com" <homotopytypetheory AT googlegroups.com>
- Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Thu, 9 Jan 2014 00:37:05 +0100
Bruno, I like to read your habilitation thesis (I hope it is not in
French). Where can I find it?
Cheers, Andreas
On 08.01.14 10:45 PM, Bruno Barras wrote:
> On 08/01/2014 20:55, Vladimir Voevodsky wrote:
>> On Jan 8, 2014, at 12:40 PM, Cody Roux
>> wrote:
>>> That's fair, but I don't see why eliminators have a more powerful
>>> ontological status than sized-types. They require work to be derived as
>>> well, and the correctness proofs for them are quite similar to that for
>>> sized types. This seems like a matter of preference. Obviously I'm not
>>> neutral in this matter though.
>>> Best,
>>> Cody
>> In the case of the univalent model eliminators are better because I have
>> invested a lot of effort into checking that they are compatible with the
>> model (some details of it are at the end of my "Notes on Type Systems").
> As Cody said, it is likely that a lot of this work can be reused (or at
> least adapted) if you switch to sized-types. The only new ingredient is
> ordinal iteration, and the fact that those ordinals are not used in the
> process you iterate. This is what I call "stage irrelevance" in my
> habilitation thesis. Andreas has something similar in his
> implementation. IIUC it's an implicit product, which is much more
> flexible than stage irrelevance, but harder to understand set-theoretically.
> I must admit that the situation is quite different with higher inductive
> types. The eliminator does not split into pattern-matching + fixpoint in
> the obvious way. That's the main blocking issue I'm facing in my
> implementation of HITs. (I've tried to explain this in Barcelona last
> September.) However, I'm not going to surrender so easily.
> Bruno.
> _______________________________________________
> Agda mailing list
> Agda AT lists.chalmers.se
> https://lists.chalmers.se/mailman/listinfo/agda
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, (continued)
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Bruno Barras, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andrej Bauer, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Maxime Dénès, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Dan Doel, 01/08/2014
