Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
- To: Vincent <vincent.laporte AT gmail.com>, coq club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
- Date: Mon, 7 Apr 2014 00:21:28 +0300
> Definition nat_cases (n: nat) :
> { n' : nat | n = S n' } + {n = 0} :=
> match n with
> | O => inright _ eq_refl
> | S n' => inleft _ (exist _ n' eq_refl)
> end.
> Goal ∀ n : nat, True.
> intros n.
> refine
> match nat_cases n with
> | inleft (exist n' NZ) => _
> | inright Z => _
> end.
> Abort.
Thanks for your answer. I tried using this but I'm getting this error:
> Recursive call to fn has principal argument equal to "n'" instead of
> a subterm of "steps_left".
but n' is already a subterm of steps_left. What am I doing wrong?
Here's my program: (error is given when last line is executed)
Require Import Omega.
Require Import Coq.Vectors.Vector.
Require Import Coq.Vectors.VectorDef.
Open Scope vector_scope.
Require Import Bool.
Require Import List.
Require Import Arith.
Require Import Arith.EqNat.
Require Import Program.
Definition admit {T: Type} : T. Admitted.
CoInductive triangle_t (T : Type) : nat -> Type :=
| triangle : forall (n : nat), Vector.t T n -> triangle_t T (S n) ->
triangle_t T n.
match n with
end.
Definition nth_triangle_aux
: forall T steps_left stop,
stop >= steps_left -> triangle_t T (stop - steps_left) -> Vector.t T
stop.
refine (fix fn T (steps_left stop : nat)
(pf : stop >= steps_left)
(tr : triangle_t T (stop - steps_left))
: Vector.t T stop :=
match nat_cases steps_left return Vector.t T stop with
| inright Z => _
end).
apply fn with (steps_left := n').
rewrite NZ in pf. omega.
rewrite NZ in tr. inversion tr; subst.
assert (S (stop - S n') = stop - n'). omega.
rewrite H in X0. apply X0.
subst. rewrite <- minus_n_O in tr. inversion tr; auto.
Defined.
Ömer Sinan Ağacan
http://osa1.net
- [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Ömer Sinan Ağacan, 04/06/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Gabriel Scherer, 04/06/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, AUGER Cédric, 04/06/2014
- Message not available
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Ömer Sinan Ağacan, 04/06/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Ömer Sinan Ağacan, 04/07/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Adam Chlipala, 04/07/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Arthur Azevedo de Amorim, 04/07/2014
