coq-club - Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
  • To: coq club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
  • Date: Mon, 7 Apr 2014 13:15:45 +0300
It works, but I don't understand how can this work. Can anyone explain
how is this definition different than:
Fixpoint pt_aux h len (v : Vector.t nat len) : Vector.t nat len :=
match v with
| Vector.nil => v
| Vector.cons h' _ t' =>
Vector.cons nat (h + h') _ (pt_aux h' _ t')
end.
Ömer Sinan Ağacan
http://osa1.net
2014-04-07 12:54 GMT+03:00 Arthur Azevedo de Amorim
<arthur.aa AT gmail.com>:
> Does this work?
> Require Vector.
> Import Vector.VectorNotations.
> match v with
> | h' :: v' => (h + h') :: pt_aux h' _ v'
> end.
> 2014-04-07 11:45 GMT+02:00 Ömer Sinan Ağacan
> <omeragacan AT gmail.com>:
>> I'm stuck again :-) Coq gives this error:
>> The term "Vector.cons nat (h + h') l' (fn h' l' t')" has type
>> "Vector.t nat (S l')" while it is expected to have type "Vector.t nat
>> len".
>> in this code:
>> Definition pt_aux : forall (h len : nat), Vector.t nat len ->
>> Vector.t nat len :=
>> fix fn h len v :=
>> match v return Vector.t nat len with
>> | Vector.nil => v
>> | Vector.cons h' l' t' =>
>> end.
>> so I need to somehow tell Coq that S l' = len, because t' is tail part
>> of vector v and v has length len.
>> I tried implementing something like
>> Definition vector_cases {T : Type} (len len' : nat) (v : Vector.t T len)
>> {ve : T * Vector.t T len' | len = S len'} + {len = 0}.
>> but this is obviously wrong, because I need to get len' as return, I
>> don't know if such a len' exists or if it does, whar is it. I don't
>> know how to encode this idea in Coq.
>> Maybe I should read one or two more chapters in CPDT :-)
>> Ömer Sinan Ağacan
>> http://osa1.net
