Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
- From: Arthur Azevedo de Amorim <arthur.aa AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
- Date: Mon, 7 Apr 2014 12:24:07 +0200
The problem is that you are trying to return v on the nil branch, and
Coq is not smart enough to understand that it should have length zero
because it is the very same thing you just did pattern-matching on. If
you need to absolutely use v on that branch, you need to apply the
convoy pattern and reabstract it:
Fixpoint pt_aux h len (v : Vector.t nat len) : Vector.t nat len :=
match v in Vector.t _ len return Vector.t _ len -> Vector.t _ len with
| [] => fun v => v
| h' :: v' => fun _ => (h + h') :: pt_aux h' _ v'
end v.
Notice how the match is returning a function, which is the identity in
the nil case, and that the variable is discarded in the cons case.
2014-04-07 12:15 GMT+02:00 Ömer Sinan Ağacan
<omeragacan AT gmail.com>:
> It works, but I don't understand how can this work. Can anyone explain
> how is this definition different than:
> match v with
> | Vector.nil => v
> | Vector.cons h' _ t' =>
> Vector.cons nat (h + h') _ (pt_aux h' _ t')
> end.
> Ömer Sinan Ağacan
> http://osa1.net
> 2014-04-07 12:54 GMT+03:00 Arthur Azevedo de Amorim
> <arthur.aa AT gmail.com>:
>> Does this work?
>> Require Vector.
>> Import Vector.VectorNotations.
>> match v with
>> | h' :: v' => (h + h') :: pt_aux h' _ v'
>> end.
>> 2014-04-07 11:45 GMT+02:00 Ömer Sinan Ağacan
>>> I'm stuck again :-) Coq gives this error:
>>> The term "Vector.cons nat (h + h') l' (fn h' l' t')" has type
>>> "Vector.t nat (S l')" while it is expected to have type "Vector.t nat
>>> len".
>>> in this code:
>>> Definition pt_aux : forall (h len : nat), Vector.t nat len ->
>>> Vector.t nat len :=
>>> fix fn h len v :=
>>> match v return Vector.t nat len with
>>> | Vector.nil => v
>>> | Vector.cons h' l' t' =>
>>> end.
>>> so I need to somehow tell Coq that S l' = len, because t' is tail part
>>> of vector v and v has length len.
>>> I tried implementing something like
>>> Definition vector_cases {T : Type} (len len' : nat) (v : Vector.t T
>>> len) :
>>> {ve : T * Vector.t T len' | len = S len'} + {len = 0}.
>>> but this is obviously wrong, because I need to get len' as return, I
>>> don't know if such a len' exists or if it does, whar is it. I don't
>>> know how to encode this idea in Coq.
>>> Maybe I should read one or two more chapters in CPDT :-)
>>> Ömer Sinan Ağacan
>>> http://osa1.net
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, (continued)
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, AUGER Cédric, 04/06/2014
- Message not available
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Ömer Sinan Ağacan, 04/06/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Ömer Sinan Ağacan, 04/07/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Adam Chlipala, 04/07/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Arthur Azevedo de Amorim, 04/07/2014
