Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
- To: coq club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
- Date: Mon, 7 Apr 2014 13:28:50 +0300
This is weird. Coq was saying that the problem is with cons branch,
not nil branch. But when I changed nil branch it worked. So this also
works:
Fixpoint pt_aux h len (v : Vector.t nat len) : Vector.t nat len :=
match v with
| Vector.nil => Vector.nil nat
| Vector.cons h' _ t' =>
Vector.cons nat (h + h') _ (pt_aux h' _ t')
end.
Thanks again.
Ömer Sinan Ağacan
http://osa1.net
2014-04-07 13:24 GMT+03:00 Arthur Azevedo de Amorim
<arthur.aa AT gmail.com>:
> The problem is that you are trying to return v on the nil branch, and
> Coq is not smart enough to understand that it should have length zero
> because it is the very same thing you just did pattern-matching on. If
> you need to absolutely use v on that branch, you need to apply the
> convoy pattern and reabstract it:
> match v in Vector.t _ len return Vector.t _ len -> Vector.t _ len with
> | [] => fun v => v
> | h' :: v' => fun _ => (h + h') :: pt_aux h' _ v'
> end v.
> Notice how the match is returning a function, which is the identity in
> the nil case, and that the variable is discarded in the cons case.
> 2014-04-07 12:15 GMT+02:00 Ömer Sinan Ağacan
> <omeragacan AT gmail.com>:
>> It works, but I don't understand how can this work. Can anyone explain
>> how is this definition different than:
>> match v with
>> | Vector.nil => v
>> end.
>> Ömer Sinan Ağacan
>> http://osa1.net
>> 2014-04-07 12:54 GMT+03:00 Arthur Azevedo de Amorim
>>> Does this work?
>>> Require Vector.
>>> Import Vector.VectorNotations.
>>> match v with
>>> | h' :: v' => (h + h') :: pt_aux h' _ v'
>>> end.
>>> 2014-04-07 11:45 GMT+02:00 Ömer Sinan Ağacan
>>>> I'm stuck again :-) Coq gives this error:
>>>> The term "Vector.cons nat (h + h') l' (fn h' l' t')" has type
>>>> "Vector.t nat (S l')" while it is expected to have type "Vector.t nat
>>>> len".
>>>> in this code:
>>>> Definition pt_aux : forall (h len : nat), Vector.t nat len ->
>>>> Vector.t nat len :=
>>>> fix fn h len v :=
>>>> match v return Vector.t nat len with
>>>> | Vector.nil => v
>>>> | Vector.cons h' l' t' =>
>>>> end.
>>>> so I need to somehow tell Coq that S l' = len, because t' is tail part
>>>> of vector v and v has length len.
>>>> I tried implementing something like
>>>> Definition vector_cases {T : Type} (len len' : nat) (v : Vector.t T
>>>> len) :
>>>> {ve : T * Vector.t T len' | len = S len'} + {len = 0}.
>>>> but this is obviously wrong, because I need to get len' as return, I
>>>> don't know if such a len' exists or if it does, whar is it. I don't
>>>> know how to encode this idea in Coq.
>>>> Maybe I should read one or two more chapters in CPDT :-)
>>>> Ömer Sinan Ağacan
>>>> http://osa1.net
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, (continued)
- Message not available
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Ömer Sinan Ağacan, 04/06/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, AUGER Cédric, 04/06/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Ömer Sinan Ağacan, 04/07/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Arthur Azevedo de Amorim, 04/07/2014
- Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode, Adam Chlipala, 04/07/2014
