coq-club - Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
  • To: Vincent <vincent.laporte AT gmail.com>, coq club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
  • Date: Mon, 7 Apr 2014 00:39:52 +0300
I made it working with a small addition to the code:
Definition nth_triangle_aux
: forall T steps_left stop,
stop >= steps_left -> triangle_t T (stop - steps_left) -> Vector.t T
stop.
refine (fix fn T (steps_left stop : nat)
(pf : stop >= steps_left)
(tr : triangle_t T (stop - steps_left))
: Vector.t T stop :=
match nat_cases steps_left return Vector.t T stop with
| inleft (exist n' NZ) => _
| inright Z => _
end).
destruct steps_left.
inversion NZ.
apply fn with (steps_left := steps_left).
rewrite NZ in pf. omega.
rewrite NZ in tr. inversion tr; subst.
assert (S (stop - S n') = stop - n'). omega.
rewrite H in X0. inversion NZ; subst. apply X0.
subst. rewrite <- minus_n_O in tr. inversion tr; auto.
Defined.
I'm still wondering if there's a way to tell Coq that n' is already a
subterm of steps_left.
Ömer Sinan Ağacan
http://osa1.net
2014-04-07 0:21 GMT+03:00 Ömer Sinan Ağacan
<omeragacan AT gmail.com>:
>> Definition nat_cases (n: nat) :
>> { n' : nat | n = S n' } + {n = 0} :=
>> match n with
>> | O => inright _ eq_refl
>> | S n' => inleft _ (exist _ n' eq_refl)
>> end.
>> Goal ∀ n : nat, True.
>> intros n.
>> refine
>> match nat_cases n with
>> | inright Z => _
>> end.
>> Abort.
> Thanks for your answer. I tried using this but I'm getting this error:
>> Recursive call to fn has principal argument equal to "n'" instead of
>> a subterm of "steps_left".
> but n' is already a subterm of steps_left. What am I doing wrong?
> Here's my program: (error is given when last line is executed)
> Require Import Omega.
> Require Import Coq.Vectors.Vector.
> Require Import Coq.Vectors.VectorDef.
> Open Scope vector_scope.
> Require Import Bool.
> Require Import List.
> Require Import Arith.
> Require Import Arith.EqNat.
> Require Import Program.
> Definition admit {T: Type} : T. Admitted.
> CoInductive triangle_t (T : Type) : nat -> Type :=
> | triangle : forall (n : nat), Vector.t T n -> triangle_t T (S n) ->
> triangle_t T n.
> match n with
> end.
> stop.
> | inright Z => _
> end).
> apply fn with (steps_left := n').
> rewrite H in X0. apply X0.
> Defined.
> Ömer Sinan Ağacan
> http://osa1.net
