coq-club - Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
  • To: coq club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
  • Date: Mon, 7 Apr 2014 10:54:44 +0300
> Definition nth_triangle_aux
> : forall T steps_left stop,
> stop >= steps_left -> triangle_t T (stop - steps_left) ->
> Vector.t T stop. intros T.
> refine (fix fn (steps_left stop : nat)
> : (stop >= steps_left) -> (triangle_t T (stop -
> steps_left)) -> Vector.t T stop :=
> fun pf tr =>
> match steps_left as sl return steps_left = sl -> Vector.t T stop
> with | S n' => fun NZ => _
> | O => fun Z => _
> end (eq_refl steps_left)).
> subst. rewrite <- minus_n_O in tr. inversion tr; auto.
> apply fn with (steps_left := n').
> rewrite NZ in pf. omega.
> rewrite NZ in tr. inversion tr; subst.
> assert (S (stop - S n') = stop - n'). omega.
> rewrite H in X0. apply X0.
> Defined.
This worked great, thanks! Generated OCaml code also better now:
(** val nth_triangle_aux : nat -> nat -> 'a1 triangle_t -> 'a1 t **)
let rec nth_triangle_aux steps_left stop tr =
match steps_left with
| O -> let Triangle (n, x, x0) = Lazy.force tr in x
| S n' ->
nth_triangle_aux n' stop (let Triangle (n, x, x0) = Lazy.force tr in x0)
Thanks again!
Ömer Sinan Ağacan
http://osa1.net
2014-04-07 3:01 GMT+03:00 AUGER Cédric
<sedrikov AT gmail.com>:
> Le Mon, 7 Apr 2014 00:21:28 +0300,
> Ömer Sinan Ağacan
> <omeragacan AT gmail.com>
> a écrit :
>> > Definition nat_cases (n: nat) :
>> > { n' : nat | n = S n' } + {n = 0} :=
>> > match n with
>> > | O => inright _ eq_refl
>> > | S n' => inleft _ (exist _ n' eq_refl)
>> > end.
>> > Goal ∀ n : nat, True.
>> > intros n.
>> > refine
>> > match nat_cases n with
>> > | inleft (exist n' NZ) => _
>> > | inright Z => _
>> > end.
>> > Abort.
>> Thanks for your answer. I tried using this but I'm getting this error:
>> > Recursive call to fn has principal argument equal to "n'" instead of
>> > a subterm of "steps_left".
>> but n' is already a subterm of steps_left. What am I doing wrong?
>> Here's my program: (error is given when last line is executed)
>> Require Import Omega.
>> Require Import Coq.Vectors.Vector.
>> Require Import Coq.Vectors.VectorDef.
>> Open Scope vector_scope.
>> Require Import Bool.
>> Require Import List.
>> Require Import Arith.
>> Require Import Arith.EqNat.
>> Require Import Program.
>> Definition admit {T: Type} : T. Admitted.
>> CoInductive triangle_t (T : Type) : nat -> Type :=
>> | triangle : forall (n : nat), Vector.t T n -> triangle_t T (S n) ->
>> triangle_t T n.
>> match n with
>> end.
>> Vector.t T stop. refine (fix fn T (steps_left stop : nat)
>> (pf : stop >= steps_left)
>> (tr : triangle_t T (stop - steps_left))
>> : Vector.t T stop :=
>> match nat_cases steps_left return Vector.t T stop with
>> | inright Z => _
>> end).
>> Defined.
>> Ömer Sinan Ağacan
>> http://osa1.net
> Sorry for indentation breaking. n' was not a subterm of steps_left, but
> rather a subterm of "nat_cases steps_left", which is completely
> different from Coq point of view. The following code works:
> But I often prefer to do things like that, where you do not have to
> introduce equalities to eliminate them later.
> return (stop >= sl) -> (triangle_t T (stop - sl)) -> Vector.t T
> stop with | S n' => _
> | O => _
> end).
> rewrite <- minus_n_O. intros _ [n v _]. exact v.
> intros pf tr; apply fn with (steps_left := n').
> apply le_trans with (S n'); auto.
> case H; case tr.
> auto.
> Defined.
