coq-club - Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Why I'm not getting any equalities as hypothesis in while filling underscores in proof mode
  • Date: Mon, 7 Apr 2014 02:01:00 +0200
Le Mon, 7 Apr 2014 00:21:28 +0300,
Ömer Sinan Ağacan
<omeragacan AT gmail.com>
a écrit :
> > Definition nat_cases (n: nat) :
> > { n' : nat | n = S n' } + {n = 0} :=
> > match n with
> > | O => inright _ eq_refl
> > | S n' => inleft _ (exist _ n' eq_refl)
> > end.
> > Goal ∀ n : nat, True.
> > intros n.
> > refine
> > match nat_cases n with
> > | inleft (exist n' NZ) => _
> > | inright Z => _
> > end.
> > Abort.
> Thanks for your answer. I tried using this but I'm getting this error:
> > Recursive call to fn has principal argument equal to "n'" instead of
> > a subterm of "steps_left".
> but n' is already a subterm of steps_left. What am I doing wrong?
> Here's my program: (error is given when last line is executed)
> Require Import Omega.
> Require Import Coq.Vectors.Vector.
> Require Import Coq.Vectors.VectorDef.
> Open Scope vector_scope.
> Require Import Bool.
> Require Import List.
> Require Import Arith.
> Require Import Arith.EqNat.
> Require Import Program.
> Definition admit {T: Type} : T. Admitted.
> CoInductive triangle_t (T : Type) : nat -> Type :=
> | triangle : forall (n : nat), Vector.t T n -> triangle_t T (S n) ->
> triangle_t T n.
> match n with
> end.
> Definition nth_triangle_aux
> : forall T steps_left stop,
> stop >= steps_left -> triangle_t T (stop - steps_left) ->
> Vector.t T stop. refine (fix fn T (steps_left stop : nat)
> (pf : stop >= steps_left)
> (tr : triangle_t T (stop - steps_left))
> : Vector.t T stop :=
> match nat_cases steps_left return Vector.t T stop with
> | inright Z => _
> end).
> apply fn with (steps_left := n').
> rewrite NZ in pf. omega.
> rewrite NZ in tr. inversion tr; subst.
> assert (S (stop - S n') = stop - n'). omega.
> rewrite H in X0. apply X0.
> subst. rewrite <- minus_n_O in tr. inversion tr; auto.
> Defined.
> Ömer Sinan Ağacan
> http://osa1.net
Sorry for indentation breaking. n' was not a subterm of steps_left, but
rather a subterm of "nat_cases steps_left", which is completely
different from Coq point of view. The following code works:
Vector.t T stop. intros T.
refine (fix fn (steps_left stop : nat)
: (stop >= steps_left) -> (triangle_t T (stop -
steps_left)) -> Vector.t T stop :=
fun pf tr =>
match steps_left as sl return steps_left = sl -> Vector.t T stop
with | S n' => fun NZ => _
| O => fun Z => _
end (eq_refl steps_left)).
Defined.
But I often prefer to do things like that, where you do not have to
introduce equalities to eliminate them later.
return (stop >= sl) -> (triangle_t T (stop - sl)) -> Vector.t T
stop with | S n' => _
| O => _
end).
rewrite <- minus_n_O. intros _ [n v _]. exact v.
intros pf tr; apply fn with (steps_left := n').
apply le_trans with (S n'); auto.
case H; case tr.
auto.
Defined.
