coq-club - Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
  • Date: Thu, 24 Jul 2014 12:43:42 -0400
On 07/24/2014 11:57 AM, Arnaud Spiwack wrote:
Well, you are not forced to solve two subgoals. It's just that the
existential variable which is introduced is materialised as a goal. You can
use tactics in the first subgoal to give (partially) solve it such as in:
Goal exists n, n=0.
Proof.
refine (ex_intro _ _ _);[refine (S _) |].
(of course [refine] is not that interesting as you could use [instantiate],
but you are really free to use any tactic). The existential is not
identified by a place in a term but by the corresponding goal. On the other
hand, the goal can be solved by side effects as in:
Goal exists n, n=0.
Proof.
refine (ex_intro _ _ _);[|reflexivity].
Nothing has been done in the first goal, but you may check that the proof
engine sees it has been solved.
Oh - that's somewhat interesting. The subgoals are linked.
But I still don't understand what the benefit of this new first subgoal that I get via refine (ex_intro _ _ _), but not via eexists. It's weaker than the second subgoal, since it is solvable without the "=0" constraint. Solving the second subgoal solves the first, but nothing done in the first subgoal aids in solving the second - quite the opposite - most solutions of the first subgoal make the second unsolvable.
When are these extra subgoals produced by refine useful?
-- Jonathan
