- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] question about universes and equalities
- Date: Mon, 9 May 2016 19:36:14 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f41.google.com
- Ironport-phdr: 9a23:JP0FOh2kZk0jpsqEsmDT+DRfVm0co7zxezQtwd8ZsegVI/ad9pjvdHbS+e9qxAeQG96LurQd0KGM6ujJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6DyZ3snLrrs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGCmI4HIAUmwQ2j5FAhbI6g2yCpX2tCr5u+5w1QGVOMT3SfY/XjH0vPQjcwPhlCpSb21xy2rQkMEl1K8=
On 05/09/2016 07:18 PM, Clément Pit--Claudel wrote:
I'm not sure I understand correctly:
Inductive foo (A : Type) (x : A) : A -> Type :=
Build_foo (y z : A) : x <> y -> x <> z -> y <> z -> foo A x x.
Lemma out_of_thin_air : forall {T1 T2: Set},
The slight change here from {T1 T2 : Prop} to {T1 T2 : Set} makes the difference.
T1 = T2 -> T1 -> T2.
Proof.
destruct 1; apply id.
Qed.
Lemma true_neq_false: not (@eq Set True False).
intro Heq.
destruct (@out_of_thin_air True False Heq I).
Qed.
Goal foo Set True True.
eapply (Build_foo Set _ False bool).
apply true_neq_false.
Got it:
Proof.
Qed.
intro Heq.
Qed.
Lemma alltrue : forall (x y : True), x = y.
intros.
destruct x, y.
reflexivity.
Qed.
Lemma true_neq_bool: not (@eq Set True bool).
intro Heq.
assert (true <> false) by discriminate.
assert (true = false).
pose alltrue.
rewrite Heq in e.
apply e.
contradict H.
assumption.
Qed.
Lemma false_neq_bool : not (@eq Set False bool).
intro Heq.
symmetry in Heq.
pose (out_of_thin_air Heq) as f.
apply f.
exact true.
Qed.
apply true_neq_bool.
apply false_neq_bool.
Qed.
So, this means universe reduction for arbitrary relations is not a good idea. But, maybe just for eq...?
-- Jonathan
On 2016-05-09 18:45, Jonathan Leivent wrote:
Oops...
Lemma out_of_thin_air : forall {T1 T2: Prop},
Proof.
Qed.
Lemma true_neq_false: True <> False.
intro Heq.
Qed.
the apply fails with Error: Unable to unify "not (@eq Prop True False)" with "not
(@eq Set True False)".
I guess I misunderstood Jason as saying that [foo Set True True] is already
inhabited, but maybe he was instead saying that it would be inhabited if this
kind of eq level reduction occurred?
-- Jonathan
On 05/09/2016 06:22 PM, Clément Pit--Claudel wrote:
Does this work?
Proof.
Qed.
Goal True <> False.
intro Heq.
Qed.
On 2016-05-09 18:03, Jonathan Leivent wrote:
Are you sure that thing is inhabited as you say? I can't prove it - I end up with subgoals
like "True <> False", which I don't think can be proven.
Even if it were, can't such a collapsing reduction be only about equalities,
in much the same way that axiom K is only about equalities?
-- Jonathan
On 05/09/2016 05:12 PM, Jason Gross wrote:
You're playing with fire here. Consider the inductive type
Inductive foo (A : Type) (x : A) : A -> Type := Build_foo (y z : A) : x <>
Then [foo Set True True] is inhabited (let y be False and z be bool), but
[foo Prop True True] contradicts prop_extensionality+LEM and so cannot be
inhabited.
What rule for universes of inductive types can you formulate that permits
what you want for equality but forbids collapsing [foo Set True True] is to
[foo Prop True True]?
On Mon, May 9, 2016, 4:01 PM Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
On 05/09/2016 03:48 PM, Stefan Monnier wrote:
I'd just like to make it go away. Specifically, I'd like [@eq Type@{i}Note that [@eq Type@{i} A B -> @eq Type@{j} A B] does not hold for [ij],
Hmm.. which part of Coq's typing rules cause this?
Stefan
A B] to reduce to [@eq Type@{j} A B] where j is the minimum permissible
level considering A and B.
I guess one could have a type theory where some things are provably
equal at higher levels but not at lower ones. But, such a thing seems
quite bizarre.
-- Jonathan
- Re: [Coq-Club] question about universes and equalities, (continued)
- Re: [Coq-Club] question about universes and equalities, Jason Gross, 05/09/2016
- Re: [Coq-Club] question about universes and equalities, Jonathan Leivent, 05/09/2016
- Re: [Coq-Club] question about universes and equalities, Jonathan Leivent, 05/10/2016
- Re: [Coq-Club] question about universes and equalities, Clément Pit--Claudel, 05/10/2016
- Re: [Coq-Club] question about universes and equalities, Jason Gross, 05/10/2016
