coq-club - Re: [Coq-Club] question about universes and equalities
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] question about universes and equalities
  • Date: Mon, 9 May 2016 19:18:59 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
  • Ironport-phdr: 9a23:tlH66hajtWxb6bAdFP+ddA3/LSx+4OfEezUN459isYplN5qZpci/bnLW6fgltlLVR4KTs6sC0LqH9fm7EjZZqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7H0osaYOVwArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq8/VPlTCCksG2Ez/szi8xfZHiWV4X5JeWGXlxdOHz/97Q2/G7z1uzb2u+41jCKeMMj7S6xyQTW+x6huQR7sziwAMmhqoynslsVsgfcD81qarBtlztuMbQ==
I'm not sure I understand correctly:
Inductive foo (A : Type) (x : A) : A -> Type :=
Build_foo (y z : A) : x <> y -> x <> z -> y <> z -> foo A x x.
Lemma out_of_thin_air : forall {T1 T2: Set},
T1 = T2 -> T1 -> T2.
Proof.
destruct 1; apply id.
Qed.
Lemma true_neq_false: not (@eq Set True False).
intro Heq.
destruct (@out_of_thin_air True False Heq I).
Qed.
Goal foo Set True True.
eapply (Build_foo Set _ False bool).
apply true_neq_false.
On 2016-05-09 18:45, Jonathan Leivent wrote:
> Oops...
> Lemma out_of_thin_air : forall {T1 T2: Prop},
> Proof.
> Qed.
> Lemma true_neq_false: True <> False.
> intro Heq.
> Qed.
> the apply fails with Error: Unable to unify "not (@eq Prop True False)"
> with "not (@eq Set True False)".
> I guess I misunderstood Jason as saying that [foo Set True True] is already
> inhabited, but maybe he was instead saying that it would be inhabited if
> this kind of eq level reduction occurred?
> -- Jonathan
> On 05/09/2016 06:22 PM, Clément Pit--Claudel wrote:
>> Does this work?
>> Proof.
>> Qed.
>> Goal True <> False.
>> intro Heq.
>> Qed.
>> On 2016-05-09 18:03, Jonathan Leivent wrote:
>>> Are you sure that thing is inhabited as you say? I can't prove it - I
>>> end up with subgoals like "True <> False", which I don't think can be
>>> proven.
>>> Even if it were, can't such a collapsing reduction be only about
>>> equalities, in much the same way that axiom K is only about equalities?
>>> -- Jonathan
>>> On 05/09/2016 05:12 PM, Jason Gross wrote:
>>>> You're playing with fire here. Consider the inductive type
>>>> Inductive foo (A : Type) (x : A) : A -> Type := Build_foo (y z : A) : x
>>>> Then [foo Set True True] is inhabited (let y be False and z be bool), but
>>>> [foo Prop True True] contradicts prop_extensionality+LEM and so cannot be
>>>> inhabited.
>>>> What rule for universes of inductive types can you formulate that permits
>>>> what you want for equality but forbids collapsing [foo Set True True] is
>>>> to
>>>> [foo Prop True True]?
>>>> On Mon, May 9, 2016, 4:01 PM Jonathan Leivent
>>>> <jonikelee AT gmail.com>
>>>> wrote:
>>>>> On 05/09/2016 03:48 PM, Stefan Monnier wrote:
>>>>>>> Note that [@eq Type@{i} A B -> @eq Type@{j} A B] does not hold for [i
>>>>>> j],
>>>>>> Hmm.. which part of Coq's typing rules cause this?
>>>>>> Stefan
>>>>> I'd just like to make it go away. Specifically, I'd like [@eq Type@{i}
>>>>> A B] to reduce to [@eq Type@{j} A B] where j is the minimum permissible
>>>>> level considering A and B.
>>>>> I guess one could have a type theory where some things are provably
>>>>> equal at higher levels but not at lower ones. But, such a thing seems
>>>>> quite bizarre.
>>>>> -- Jonathan
Attachment: signature.asc
Description: OpenPGP digital signature
