coq-club - Re: [Coq-Club] question about universes and equalities
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] question about universes and equalities
  • Date: Mon, 9 May 2016 18:42:46 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
  • Ironport-phdr: 9a23:mJsa3BTz4YbI8v442hh4vKbuLtpsv+yvbD5Q0YIujvd0So/mwa64YBGN2/xhgRfzUJnB7Loc0qyN4/GmADdLucfJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuKOE4Q1XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrtBST8iLmod5cvxtBCFQxHcyGEbVzA9lptNDg7Z2yn7QtK0mS/zq+Zw3GHONsn7SL0yRXK67rtDRxrhiSNBPDk8pjKEwvdshb5W9Ury7yd0xJTZNdmY
Actually, I overlooked a much simpler proof:
Definition True_not_False : True <> False :=
fun H => let 'eq_refl := H in I.
which you essentially get from
Goal True <> False.
destruct 1; exact I.
Qed.
Clément.
On 2016-05-09 18:22, Clément Pit--Claudel wrote:
> Does this work?
> Lemma out_of_thin_air : forall {T1 T2: Prop},
> T1 = T2 -> T1 -> T2.
> Proof.
> destruct 1; apply id.
> Qed.
> Goal True <> False.
> intro Heq.
> destruct (@out_of_thin_air True False Heq I).
> Qed.
> On 2016-05-09 18:03, Jonathan Leivent wrote:
>> Are you sure that thing is inhabited as you say? I can't prove it - I end
>> up with subgoals like "True <> False", which I don't think can be proven.
>> Even if it were, can't such a collapsing reduction be only about
>> equalities, in much the same way that axiom K is only about equalities?
>> -- Jonathan
>> On 05/09/2016 05:12 PM, Jason Gross wrote:
>>> You're playing with fire here. Consider the inductive type
>>> Inductive foo (A : Type) (x : A) : A -> Type := Build_foo (y z : A) : x <>
>>> y -> x <> z -> y <> z -> foo A x x.
>>> Then [foo Set True True] is inhabited (let y be False and z be bool), but
>>> [foo Prop True True] contradicts prop_extensionality+LEM and so cannot be
>>> inhabited.
>>> What rule for universes of inductive types can you formulate that permits
>>> what you want for equality but forbids collapsing [foo Set True True] is
>>> to
>>> [foo Prop True True]?
>>> On Mon, May 9, 2016, 4:01 PM Jonathan Leivent
>>> <jonikelee AT gmail.com>
>>> wrote:
>>>> On 05/09/2016 03:48 PM, Stefan Monnier wrote:
>>>>>> Note that [@eq Type@{i} A B -> @eq Type@{j} A B] does not hold for [i
>>>>> j],
>>>>> Hmm.. which part of Coq's typing rules cause this?
>>>>> Stefan
>>>> I'd just like to make it go away. Specifically, I'd like [@eq Type@{i}
>>>> A B] to reduce to [@eq Type@{j} A B] where j is the minimum permissible
>>>> level considering A and B.
>>>> I guess one could have a type theory where some things are provably
>>>> equal at higher levels but not at lower ones. But, such a thing seems
>>>> quite bizarre.
>>>> -- Jonathan
Attachment: signature.asc
Description: OpenPGP digital signature
