coq-club - Re: [Coq-Club] question about universes and equalities
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] question about universes and equalities
  • Date: Mon, 9 May 2016 18:45:30 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f179.google.com
  • Ironport-phdr: 9a23:Gla34BVyA7D1e6kff8tpBp8St3TV8LGtZVwlr6E/grcLSJyIuqrYZheOt8tkgFKBZ4jH8fUM07OQ6PCxHzVbqs7Q+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8yVOl4D3Gv1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/zMztrxjKCwWVtVUGVWBDsB1OChTF5ReyeprwrCb8qqIp2i6cPM77Sb05cTun5qZvDhTvjXFUZHYC7GjLh5ko3+pgqxW7qkknzg==
Oops...
Inductive foo (A : Type) (x : A) : A -> Type :=
Build_foo (y z : A) : x <> y -> x <> z -> y <> z -> foo A x x.
Lemma out_of_thin_air : forall {T1 T2: Prop},
T1 = T2 -> T1 -> T2.
Proof.
destruct 1; apply id.
Qed.
Lemma true_neq_false: True <> False.
intro Heq.
destruct (@out_of_thin_air True False Heq I).
Qed.
Goal foo Set True True.
eapply (Build_foo Set _ False bool).
apply true_neq_false.
the apply fails with Error: Unable to unify "not (@eq Prop True False)" with "not (@eq Set True False)".
I guess I misunderstood Jason as saying that [foo Set True True] is already inhabited, but maybe he was instead saying that it would be inhabited if this kind of eq level reduction occurred?
-- Jonathan
On 05/09/2016 06:22 PM, Clément Pit--Claudel wrote:
Does this work?
Proof.
Qed.
Goal True <> False.
intro Heq.
Qed.
On 2016-05-09 18:03, Jonathan Leivent wrote:
Are you sure that thing is inhabited as you say? I can't prove it - I end up with subgoals
like "True <> False", which I don't think can be proven.
Even if it were, can't such a collapsing reduction be only about equalities,
in much the same way that axiom K is only about equalities?
-- Jonathan
On 05/09/2016 05:12 PM, Jason Gross wrote:
You're playing with fire here. Consider the inductive type
Inductive foo (A : Type) (x : A) : A -> Type := Build_foo (y z : A) : x <>
Then [foo Set True True] is inhabited (let y be False and z be bool), but
[foo Prop True True] contradicts prop_extensionality+LEM and so cannot be
inhabited.
What rule for universes of inductive types can you formulate that permits
what you want for equality but forbids collapsing [foo Set True True] is to
[foo Prop True True]?
On Mon, May 9, 2016, 4:01 PM Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
On 05/09/2016 03:48 PM, Stefan Monnier wrote:
Note that [@eq Type@{i} A B -> @eq Type@{j} A B] does not hold for [i
j],
Hmm.. which part of Coq's typing rules cause this?
Stefan
I'd just like to make it go away. Specifically, I'd like [@eq Type@{i}
A B] to reduce to [@eq Type@{j} A B] where j is the minimum permissible
level considering A and B.
I guess one could have a type theory where some things are provably
equal at higher levels but not at lower ones. But, such a thing seems
quite bizarre.
-- Jonathan
