- From: Joachim Breitner <mail AT joachim-breitner.de>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] When does the termination checker reduce a record accessor?
- Date: Fri, 03 Nov 2017 09:27:34 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mail AT joachim-breitner.de; spf=Neutral smtp.mailfrom=mail AT joachim-breitner.de; spf=None smtp.helo=postmaster AT hermes.serverama.de
- Ironport-phdr: 9a23:qpRhdhye7sc/RKnXCy+O+j09IxM/srCxBDY+r6Qd0uIQIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2SkPfuEKy7CIfX1DWfUowf7ytW92as8Pi3OervpbXfg9ghTynYLo0Ig/lgx/Ws5w0hoJpKqc0gjHTr3pUfelMjTdtLFOXtxT778yw/Zsm+T5duu4n+tQGXaisLPdwdqBREDlzazN938bsrxSWCFLXvnY=
Hi,
I am stumbling about behavior of Coq’s termination checker that I
cannot explain to myself. Consider:
Require Import Coq.Lists.List.
Class C a := { P : a -> bool }.
Definition list_P {a} `{C a} : list a -> bool := existsb P.
Instance list_C {a} `{C a} : C (list a) := { P := list_P }.
(* Note that *)
Eval cbn in fun a C => (@P (list a) (@list_C a C)).
(* evaluates to: fun a C => list_P *)
Inductive tree a := Node : a -> list (tree a) -> tree a.
(* Works *)
Fixpoint tree_P1 {a} `{C a} (t : tree a) : bool :=
let tree_C := Build_C _ tree_P1 in
let list_C := Build_C _ list_P in (* Question 1: Why is this line needed
match t with Node _ x ts => orb (P x) (P ts) end.
Instance tree_C {a} `{C a} : C (tree a) := { P := tree_P1 }.
(* Works too *)
Fixpoint tree_P2 {a} `{C a} (t : tree a) : bool :=
let tree_C := Build_C _ tree_P2 in
match t with Node _ x ts => orb (P x) (list_P ts) end.
(* Does not work. Why not? *)
Fixpoint tree_P3 {a} `{C a} (t : tree a) : bool :=
let tree_C := Build_C _ tree_P3 in
match t with Node _ x ts => orb (P x) (@P _ (@list_C _ tree_C) ts) end.
(* And hence, this (identical?) code does not work *)
Fixpoint tree_P4 {a} `{C a} (t : tree a) : bool :=
let tree_C := Build_C _ tree_P4 in
The first and second example show that, when trying to understand
whether a fixpoint is terminating, Coq is able to resolve record
accessors, basically evaluating what we wrote in tree_P1 to what we
wrote in tree_P2.
But this seems to only work if the record is built locally (let tree_C
:=…), not if it is defined using Definition.
But Fixpoint can look through other definitions just fine, e.g. through
list_P. So what is special about records, and can I make Coq accept
tree_P3 and tree_P4?
Thanks,
Joachim
Joachim Breitner
http://www.joachim-breitner.de/
signature.asc
Description: This is a digitally signed message part
- [Coq-Club] When does the termination checker reduce a record accessor?, Joachim Breitner, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Tej Chajed, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Joachim Breitner, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, William J. Bowman, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Maxime Dénès, 11/03/2017
