- From: "William J. Bowman" <wjb AT williamjbowman.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] When does the termination checker reduce a record accessor?
- Date: Fri, 3 Nov 2017 15:01:22 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=wjb AT williamjbowman.com; spf=Pass smtp.mailfrom=wjb AT williamjbowman.com; spf=None smtp.helo=postmaster AT mail.williamjbowman.com
- Ironport-phdr: 9a23:WsLIJBx7ue4/AHHXCy+O+j09IxM/srCxBDY+r6Qd0uwTIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSi56idXERHiPyJ0IP70E8jclZeZzee3rtfsYgFMhTO4KZE0ZD+xsgDYsINe1ZRgII4uyx/No3JNee5R2mZhIxSYmBOqtZT4x4Jq7ykF46FpzMVHS6ivJ6k=
I agree with Tej that the problems in your code appear to result from scope
and type classes, but I want to point out something about the termination
checker some find surprising.
The Coq termination checker normalizes the body of a recursive function
*before* checking that it terminates. The typing rule is something like:
Γ,f:A ⊢ e : A
Γ,f:A ⊢ v = eval(e)
terminates(v)
Γ ⊢ (fix f:A.e) : A
That is, we type check the body `e` of a recursive function, then evaluate
`e` to a normal form `v` (with the recursive name `f` still free, so the body
can’t diverge during type checking), then check that `v` is terminating.
The let bindings in your recursive functions can thus be inlined during
evaluation, before checking termination (although, I don’t *think* this is
causing your problem). If this is surprising, you may enjoy the fact that you
can exploit this behavior to write the following well-typed expression:
Eval cbv in ((fix f (x : nat) := let n := (f x) in 0) 0).
William J. Bowman
> On Nov 3, 2017, at 2:27 PM, Joachim Breitner
> <mail AT joachim-breitner.de>
> wrote:
> Hi,
> I am stumbling about behavior of Coq’s termination checker that I
> cannot explain to myself. Consider:
> Require Import Coq.Lists.List.
> Class C a := { P : a -> bool }.
> Definition list_P {a} `{C a} : list a -> bool := existsb P.
> Instance list_C {a} `{C a} : C (list a) := { P := list_P }.
> (* Note that *)
> Eval cbn in fun a C => (@P (list a) (@list_C a C)).
> (* evaluates to: fun a C => list_P *)
> Inductive tree a := Node : a -> list (tree a) -> tree a.
> (* Works *)
> Fixpoint tree_P1 {a} `{C a} (t : tree a) : bool :=
> let tree_C := Build_C _ tree_P1 in
> let list_C := Build_C _ list_P in (* Question 1: Why is this line needed
> match t with Node _ x ts => orb (P x) (P ts) end.
> Instance tree_C {a} `{C a} : C (tree a) := { P := tree_P1 }.
> (* Works too *)
> Fixpoint tree_P2 {a} `{C a} (t : tree a) : bool :=
> let tree_C := Build_C _ tree_P2 in
> match t with Node _ x ts => orb (P x) (list_P ts) end.
> (* Does not work. Why not? *)
> Fixpoint tree_P3 {a} `{C a} (t : tree a) : bool :=
> let tree_C := Build_C _ tree_P3 in
> match t with Node _ x ts => orb (P x) (@P _ (@list_C _ tree_C) ts) end.
> (* And hence, this (identical?) code does not work *)
> Fixpoint tree_P4 {a} `{C a} (t : tree a) : bool :=
> let tree_C := Build_C _ tree_P4 in
> The first and second example show that, when trying to understand
> whether a fixpoint is terminating, Coq is able to resolve record
> accessors, basically evaluating what we wrote in tree_P1 to what we
> wrote in tree_P2.
> But this seems to only work if the record is built locally (let tree_C
> :=…), not if it is defined using Definition.
> But Fixpoint can look through other definitions just fine, e.g. through
> list_P. So what is special about records, and can I make Coq accept
> tree_P3 and tree_P4?
> Thanks,
> Joachim
> Joachim Breitner
> http://www.joachim-breitner.de/
- [Coq-Club] When does the termination checker reduce a record accessor?, Joachim Breitner, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Tej Chajed, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Joachim Breitner, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, William J. Bowman, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Maxime Dénès, 11/03/2017
