coq-club - Re: [Coq-Club] When does the termination checker reduce a record accessor?
  • From: Joachim Breitner <mail AT joachim-breitner.de>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] When does the termination checker reduce a record accessor?
  • Date: Fri, 03 Nov 2017 10:16:53 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT joachim-breitner.de; spf=Neutral smtp.mailfrom=mail AT joachim-breitner.de; spf=None smtp.helo=postmaster AT hermes.serverama.de
  • Ironport-phdr: 9a23:Ea5erRd8nDV+V45yesrJMYw2lGMj4u6mDksu8pMizoh2WeGdxc2yYh7h7PlgxGXEQZ/co6odzbGJ4+a9ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpRMMFw/ANQtpK6GwM8aSyp3vj6Hhs6HUNg5PnX+2Za54BBSwtwTY8McM0qV4LaNk6BzAqXtJfqx8325pOVSehV6o486x+LZh9C1bu/MkssRaXKTmeakiC7BVWmd1e1sp7dHm4EGQBTCE4WERByBPykJF
Hi,
Am Freitag, den 03.11.2017, 15:01 +0100 schrieb William J. Bowman:
> I agree with Tej that the problems in your code appear to result from
> scope and type classes, but I want to point out something about the
> termination checker some find surprising.
Not sure what you mean with scope, but here is the example again,
devoid of any type classes:
Require Import Coq.Lists.List.
Record C a := { P : a -> bool }.
Arguments P {_}.
Definition list_P {a} (a_C : C a) : list a -> bool := existsb (P a_C).
Definition list_C {a} (a_C : C a) : C (list a) := {| P := list_P a_C |}.
(* Note that *)
Eval cbn in fun a C => (P (list_C C)).
(* evaluates to: fun a C => list_P C *)
Inductive tree a := Node : a -> list (tree a) -> tree a.
(* Works, using a local record *)
Fixpoint tree_P1 {a} (a_C : C a) (t : tree a) : bool :=
let tree_C := Build_C _ (tree_P1 a_C) in
let list_C' := Build_C _ (list_P tree_C) in
match t with Node _ x ts => orb (P a_C x) (P list_C' ts) end.
Definition tree_C {a} {a_C : C a} : C (tree a) := {| P := tree_P1 a_C |}.
(* Works too, using list_P directly *)
Fixpoint tree_P2 {a} (a_C : C a) (t : tree a) : bool :=
let tree_C := Build_C _ (tree_P2 a_C) in
match t with Node _ x ts => orb (P a_C x) (list_P tree_C ts) end.
(* Does not work, using a globally defined record. Why not? *)
Fixpoint tree_P3 {a} (a_C : C a) (t : tree a) : bool :=
let tree_C := Build_C _ (tree_P3 a_C) in
match t with Node _ x ts => orb (P a_C x) (P (list_C tree_C) ts) end.
Again, note that the difference between tree_P2 and tree_P3 is that I
replaced (list_P tree_C) with (P (list_C tree_C)), which should be the
same, shouldn’t they?
(Sorry for the confusion introduced because of type classes…)
> The Coq termination checker normalizes the body of a recursive
> function *before* checking that it terminates.
Right, I noticed. And I am trying to use this fact here, expecting it
to reduce (P (list_C tree_C)) to (list_P tree_C).
Greetings,
Joachim
Joachim Breitner
http://www.joachim-breitner.de/
Attachment: signature.asc
Description: This is a digitally signed message part
