- From: Joachim Breitner <mail AT joachim-breitner.de>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] When does the termination checker reduce a record accessor?
- Date: Fri, 03 Nov 2017 09:56:35 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT joachim-breitner.de; spf=Neutral smtp.mailfrom=mail AT joachim-breitner.de; spf=None smtp.helo=postmaster AT hermes.serverama.de
- Ironport-phdr: 9a23:fHl2UhIKQymZloODQ9mcpTZWNBhigK39O0sv0rFitYgXIvrxwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBX/vHCo0j4TBhi6cCM9ZqGsQtaT3IyL0LW5/ISWaAFVjhK8Z6lzJVO4t1b/rM4T1KllI60xyx6BiGFFevhQyHkgcVeanhLU5MC5955i9mFaof8g68hNS+P2cvJrHvRjED06PjVtt4XQvh7ZQF7KvyNEXw==
Hi Tej,
thanks for looking into it!
Am Freitag, den 03.11.2017, 09:40 -0400 schrieb Tej Chajed:
> I saw this on Stack Exchange and started looking into it. Your first
> question really surprised me - it appears you have dead code that
> helps the termination checker. What’s going on in that the let-bound
> list_C (I’ll call it list_C’ to avoid confusion with the definition
> it shadows) is used for typeclass instantiation rather than the
> global instance.
Right, but that’s my point: list_C and list_C' seem to be mostly
equivalent to me, but somehow using list_C' allows the termination
checker to see through it, which is not the case for list_C!
> So in tree_P2 it’s not evaluation but instead typeclass resolution
> not actually using the global list_C.
Right. If you compare tree_P2 (which works) and tree_P3 (which does not
work), then the only difference is that I replaced
list_P
with
(@P _ (@list_C _ tree_C) ts)
(using the global tree_C). But the latter should reduce to the former
quite immediately, shouldn’t it?
Joachim
Joachim Breitner
http://www.joachim-breitner.de/
signature.asc
Description: This is a digitally signed message part
- [Coq-Club] When does the termination checker reduce a record accessor?, Joachim Breitner, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Tej Chajed, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Joachim Breitner, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, William J. Bowman, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Maxime Dénès, 11/03/2017
