- From: Joachim Breitner <mail AT joachim-breitner.de>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] When does the termination checker reduce a record accessor?
- Date: Fri, 03 Nov 2017 11:44:25 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT joachim-breitner.de; spf=Neutral smtp.mailfrom=mail AT joachim-breitner.de; spf=None smtp.helo=postmaster AT hermes.serverama.de
- Ironport-phdr: 9a23:/qrHJRzgDA/Z+73XCy+O+j09IxM/srCxBDY+r6Qd0uIQIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2SkPfuEKy7CIfX1DWfUowf7ytW92as8Pi3OervpbXfg9ghTynYLo0Ig/lgx/Ws5w0hoJpKqc0gjHTr3pUfelMjTdtLFOXtxT778yw/Zsm+T5duu4n+tQGXaisLPdwdqBREDlzazN938bsrxSWCFLXvnY=
Hi,
Am Freitag, den 03.11.2017, 11:11 -0400 schrieb Joachim Breitner:
> Hi,
> Am Freitag, den 03.11.2017, 16:00 +0100 schrieb William J. Bowman:
> > > On Nov 3, 2017, at 3:39 PM, Joachim Breitner
> > > wrote:
> > > Without δ, why does it unfold `list_P` and `existsb` to see that the
> > > recursion on the list is nicely structural? And why do tree_P1 and
> > > tree_P2 still work even when I specify Opaque list_P.?
> > I was about to conjecture exactly what you discovered; thank you for
> > digging into the source. And the question you pose is most
> > mysterious. Are some definitions treated differently than others?
> there is more code in that file of interest:
> | Const (kn,u) ->
> if evaluable_constant kn renv.env then
> try List.iter (check_rec_call renv []) l
> with (FixGuardError _ ) ->
> let value = (applist(constant_value renv.env (kn,u), l)) in
> check_rec_call renv stack value
> else List.iter (check_rec_call renv []) l
> so it looks like it unfolds constants on the fly, if it cannot prove
> termination without the unfolding and if they are evaluable. Great,
> that explains why it unfolds list_P and existsb. But why not P when
> applied to list_C? P certainly is not opaque.
I think I nailed it:
While the termination checker evaluates constants on demand, it only
does so when they are in head positions. In particular, it does not
evaluate the scrutinee of a match, as these examples show:
(* works *)
Fixpoint foo1 (n : nat) : nat :=
let t := Some True in
match Some True with | Some True => 0
| None => foo1 n end.
(* works *)
Fixpoint foo2 (n : nat) : nat :=
match t with | Some True => 0
| None => foo2 n end.
(* does not work *)
Definition t := Some True.
Fixpoint foo3 (n : nat) : nat :=
| None => foo3 n end.
So the problem in my original example is not that it does not evaluate
P, but that it ends up with
match list_C tree_C with …
and now it does not unfold list_C.
I wonder if I can work-around it by never defining a dictionary, but
only ever pass it to a continuation. And it does:
Require Import Coq.Lists.List.
Record C_dict a := { P' : a -> bool }.
Definition C a : Type := forall r, (C_dict a -> r) -> r.
Definition P {a} (a_C : C a) : a -> bool :=
a_C _ (P' _).
Definition list_P {a} (a_C : C a) : list a -> bool := existsb (P a_C).
Definition list_C {a} (a_C : C a) : C (list a) :=
fun _ k => k {| P' := list_P a_C |}.
Inductive tree a := Node : a -> list (tree a) -> tree a.
(* Works now! *)
Fixpoint tree_P1 {a} (a_C : C a) (t : tree a) : bool :=
let tree_C := fun _ k => k (Build_C_dict _ (tree_P1 a_C)) in
match t with Node _ x ts => orb (P a_C x) (P (list_C tree_C) ts) end.
And this now also works with type classes:
Existing Class C.
Definition P {a} {a_C : C a} : a -> bool := a_C _ (P' _).
Definition list_P {a} `{C a} : list a -> bool := existsb P.
Instance list_C {a} (a_C : C a) : C (list a) :=
fun _ k => k {| P' := list_P |}.
(* Works now! *)
let tree_C : C (tree a) := fun _ k => k (Build_C_dict _ (tree_P1
a_C)) in
match t with Node _ x ts => orb (P x) (P ts) end.
I’m not yet sure if I want to apply this pattern of defining every
instance as a continuation in my actual development, but at least there
is a way forward.
Thanks for your help,
Joachim
Joachim Breitner
http://www.joachim-breitner.de/
signature.asc
Description: This is a digitally signed message part
- [Coq-Club] When does the termination checker reduce a record accessor?, Joachim Breitner, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Tej Chajed, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Joachim Breitner, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, William J. Bowman, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Maxime Dénès, 11/03/2017
