- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] When does the termination checker reduce a record accessor?
- Date: Fri, 3 Nov 2017 16:38:19 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mail AT maximedenes.fr; spf=Pass smtp.mailfrom=mail AT maximedenes.fr; spf=None smtp.helo=postmaster AT 6.mo177.mail-out.ovh.net
- Ironport-phdr: 9a23:VYjIShMZjEaJyhcGy1sl6mtUPXoX/o7sNwtQ0KIMzox0K/n+rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6a8TWO6msZHQy6Pg5oLMz0HJTThoK5zbOc4ZrWNiBBlDu4bPterRM2tk2Fs8AXhaNnI7YwzxbFr31FYKJY3zU7dhqogx/g65Lor9ZY+CNKtqd5+g==
Hello,
I had only a brief look at your example, so I may be repeating something
that was said previously. Sorry if that's the case.
One key thing to note is that the kernel calls [whd_betaiotazeta], which
does only a weak head reduction. In particular, it won't reduce the
branches of the match in your example, whereas it will reduce the head
let-ins.
Hope it helps.
Maxime.
On 11/03/2017 03:39 PM, Joachim Breitner wrote:
> Hi,
> Am Freitag, den 03.11.2017, 15:01 +0100 schrieb William J. Bowman:
>> The Coq termination checker normalizes the body of a recursive
>> function *before* checking that it terminates. The typing rule is
>> something like:
>> Γ,f:A ⊢ e : A
>> Γ,f:A ⊢ v = eval(e)
>> terminates(v)
>> Γ ⊢ (fix f:A.e) : A
> I dug into the source code and found this:
> (* Check if [def] is a guarded fixpoint body with decreasing arg.
> given [recpos], the decreasing arguments of each mutually defined
> fixpoint. *)
> let check_one_fix renv recpos trees def =
> let nfi = Array.length recpos in
> (* Checks if [t] only make valid recursive calls *)
> let rec check_rec_call renv stack t =
> (* if [t] does not make recursive calls, it is guarded: *)
> if noccur_with_meta renv.rel_min nfi t then ()
> else
> let (f,l) = decompose_app (whd_betaiotazeta t) in
> (* Interesting bit ↑ *)
> From this I conclude that your `eval(e)` in the typing rule is actually
> ßɩζ-reduction.
> Now ζ means “contraction of local definitions”, so that explains why it
> works with a locally bound list_C'.
> And the lack of δ (unfolding of transparent constants) explains why it
> would not work with the globally defined list_C.
> And indeed,
> Eval cbv beta iota zeta in fun a C => (P (list_C C)).
> does not reduce to list_P.
> But this does not explain everything, and I’d like to get a better
> understanding what precisly is happening:
> Without δ, why does it unfold `list_P` and `existsb` to see that the
> recursion on the list is nicely structural? And why do tree_P1 and
> tree_P2 still work even when I specify Opaque list_P.?
> And I expect the answer to be no… but is there any way to make the
> termination checker reduce with delta on?
> Thanks,
> Joachim
- [Coq-Club] When does the termination checker reduce a record accessor?, Joachim Breitner, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Tej Chajed, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Joachim Breitner, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, William J. Bowman, 11/03/2017
- Re: [Coq-Club] When does the termination checker reduce a record accessor?, Maxime Dénès, 11/03/2017
