Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>, Amani Alonazi <amani.alonazi@kaust.edu.sa>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
  • Date: Mon, 14 Jan 2019 17:26:35 +0300
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=amani.alonazi@kaust.edu.sa; spf=Pass smtp.mailfrom=amani.alonazi@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f48.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Samuel,
Thanks for your input.
Where does it appear as memory node? I see node 0 and node 1 but I can't see disk in the stats output. Speaking of traces, does it take the time spent on GPUs? I don't see it in my fxt output traces.
The execute_on_all_wrapper time sometimes increases dramatically, any idea why?
Many thanks,
Amani
On Mon, Jan 14, 2019 at 4:47 PM Samuel Thibault <samuel.thibault@inria.fr> wrote:
Hello,
Amani Alonazi, le lun. 14 janv. 2019 14:44:16 +0300, a ecrit:
> I would like to profile and understand how much data are swapped in/out disk
> when enabling OOC? Is it possible? I see memory statistics from GPU/CPU and RAM
> BW. Can I get the same for disk?
The disk appears as a memory node, just like the main RAM and the GPU
RAM. Similarly, it appears in the FxT trace as a memory node, and arrows
show the transfers.
> One more thing, what is the timing of execute_on_all_wrapper? What does it
> represent?
It's just a helper to initialize CUDA on all GPUs and such.
Samuel
Amani AlOnazi
PhD Student
Extreme Computing Research Center
King Abdullah University of Science and Technology
Al-Khawarizmi (Bldg.1)
Floor 0, Office 0203-WS02
Telephone: +966 (12) 808 0218
Mobile: +966 (0) 555191795
Email: amani.alonazi@kaust.edu.sa
www.kaust.edu.sa
This message and its contents, including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
Haut de le page
