Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, Amani Alonazi <amani.alonazi@kaust.edu.sa>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
- Date: Mon, 14 Jan 2019 22:06:03 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=amani.alonazi@kaust.edu.sa; spf=Pass smtp.mailfrom=amani.alonazi@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f46.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
On Mon, Jan 14, 2019 at 9:31 PM Samuel Thibault <samuel.thibault@inria.fr> wrote:
Amani Alonazi, le lun. 14 janv. 2019 21:24:33 +0300, a ecrit:
> Hopefully last question :-) I'm using STARPU_DISK_SWAP_BACKEND=unistd. How can
> I analyze how much data transferred to disk during OOC computation? Shall I
> assume that anything exceeds the sustained BW that it runs at the sustained
> BW?
> I clearly notice the extra time required in executing each tasks with big/
> smaller STARPU_LIMIT_CPU_MEM. I just want to quantify the amount of transfer in
> /out to disk.
I'm not sure which precise information do you want. Do you mean you
want to know *during the execution* the amount of data transferred so
far?
We can easily add a function to get this.
Yes, I would like to know during the execution.
If you want to know for
the overall execution, it's the second column in
Data transfer statistics:
0 -> 1 256292.63 MB 134.42MB/s (transfers : 946 - avg 270.92 MB)
Samuel
OOC works perfectly fine. I just want to make sure that I'm getting the expected performance and quantify the BW of the application with ooc.
Many thanks,
- [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 15/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 17/01/2019
