Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>, Amani Alonazi <amani.alonazi@kaust.edu.sa>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
  • Date: Mon, 14 Jan 2019 20:46:45 +0300
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=amani.alonazi@kaust.edu.sa; spf=Pass smtp.mailfrom=amani.alonazi@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f46.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Indeed. But, StarPU statistics reports more than 90 MB/s, which is the sustained BW.
On Mon, Jan 14, 2019 at 8:41 PM Samuel Thibault <samuel.thibault@inria.fr> wrote:
Amani Alonazi, le lun. 14 janv. 2019 20:36:41 +0300, a ecrit:
> I did a benchmark of my node I/O bandwidth and it's 90 MB/s and also confirmed
> by StarPU benchmark at the beginning of the execution. Am I missing something?
For a spinning disk that would be not too surprising. Since your latency
is 30ms-ish, it looks like a spinning disk.
You could compare with the standard hdparm benchmark:
sudo hdparm -t /dev/sda
(replace sda with however your disk is called)
On one of our servers I'm getting 80MB/s. On my laptop with an nvme disk
I get a whopping 4500MB/s, it really depends on the hardware :)
Samuel
This message and its contents, including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
Haut de le page
