Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, Amani Alonazi <amani.alonazi@kaust.edu.sa>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
- Date: Mon, 14 Jan 2019 20:36:41 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=amani.alonazi@kaust.edu.sa; spf=Pass smtp.mailfrom=amani.alonazi@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f45.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Nice!
I did a benchmark of my node I/O bandwidth and it's 90 MB/s and also confirmed by StarPU benchmark at the beginning of the execution. Am I missing something?
Data transfer speed for /tmp/swap (node 2):
0 -> 2: 79 MB/s
1 -> 2: 78 MB/s
2 -> 0: 79 MB/s
2 -> 1: 78 MB/s
0 -> 2: 34219 µs
1 -> 2: 34230 µs
2 -> 0: 34219 µs
2 -> 1: 34230 µs
0 -> 2: 79 MB/s
1 -> 2: 78 MB/s
2 -> 0: 79 MB/s
2 -> 1: 78 MB/s
0 -> 2: 34219 µs
1 -> 2: 34230 µs
2 -> 0: 34219 µs
2 -> 1: 34230 µs
Data transfer statistics:
0 -> 1 256292.63 MB 134.42MB/s (transfers : 946 - avg 270.92 MB)
1 -> 0 285238.24 MB 149.60MB/s (transfers : 1049 - avg 271.91 MB)
0 -> 2 273821.92 MB 143.61MB/s (transfers : 1009 - avg 271.38 MB)
2 -> 0 228862.16 MB 120.03MB/s (transfers : 842 - avg 271.81 MB)
Total transfers: 1044214.94 MB
Many thanks!
A.
On Mon, Jan 14, 2019 at 7:01 PM Samuel Thibault <samuel.thibault@inria.fr> wrote:
Amani Alonazi, le lun. 14 janv. 2019 17:26:35 +0300, a ecrit:
> Where does it appear as memory node? I see node 0 and node 1 but I can't see
> disk in the stats output.
It should. How do you enable OOC exactly? For instance,
STARPU_BUS_STATS=1 STARPU_DISK_SWAP=/tmp STARPU_DISK_SWAP_SIZE=200 ./examples/basic_examples/vector_scal
gives
0 -> 1 0.00 MB 0.00MB/s (transfers : 0 - avg -nan MB)
1 -> 0 0.00 MB 0.00MB/s (transfers : 0 - avg -nan MB)
I don't have a GPU, so here node 1 is the disk.
In StarPU 1.3 the output will contain the node name:
Disk 0 -> NUMA 0 0.0000 GB 0.0000 MB/s (transfers : 0 - avg -nan MB)
NUMA 0 -> Disk 0 0.0000 GB 0.0000 MB/s (transfers : 0 - avg -nan MB)
> Speaking of traces, does it take the time spent on GPUs?
It should, yes.
> I don't see it in my fxt output traces.
Could you post them so we can see what it looks like?
> The execute_on_all_wrapper time sometimes increases dramatically, any idea why?
That could be just the CUBLAS initialization that happens badly
for some CUDA-ish reason which we can't do anything about. You
could check the timing of the starpu_cublas_init() call in
./runtime/starpu/control/runtime_control.c
Samuel
- [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 15/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 16/01/2019
