Archives de la liste
- To: Amani Alonazi <amani.alonazi@kaust.edu.sa>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
- Date: Mon, 14 Jan 2019 17:01:30 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Amani Alonazi, le lun. 14 janv. 2019 17:26:35 +0300, a ecrit:
> Where does it appear as memory node? I see node 0 and node 1 but I can't see
> disk in the stats output.
It should. How do you enable OOC exactly? For instance,
STARPU_BUS_STATS=1 STARPU_DISK_SWAP=/tmp STARPU_DISK_SWAP_SIZE=200
./examples/basic_examples/vector_scal
gives
Data transfer statistics:
0 -> 1 0.00 MB 0.00MB/s (transfers : 0 - avg -nan MB)
1 -> 0 0.00 MB 0.00MB/s (transfers : 0 - avg -nan MB)
I don't have a GPU, so here node 1 is the disk.
In StarPU 1.3 the output will contain the node name:
Disk 0 -> NUMA 0 0.0000 GB 0.0000 MB/s (transfers :
0 - avg -nan MB)
NUMA 0 -> Disk 0 0.0000 GB 0.0000 MB/s (transfers :
0 - avg -nan MB)
> Speaking of traces, does it take the time spent on GPUs?
It should, yes.
> I don't see it in my fxt output traces.
Could you post them so we can see what it looks like?
> The execute_on_all_wrapper time sometimes increases dramatically, any idea
> why?
That could be just the CUBLAS initialization that happens badly
for some CUDA-ish reason which we can't do anything about. You
could check the timing of the starpu_cublas_init() call in
./runtime/starpu/control/runtime_control.c
Samuel
- [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 15/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 16/01/2019
