Archives de la liste
- To: Amani Alonazi <amani.alonazi@kaust.edu.sa>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
- Date: Mon, 14 Jan 2019 18:41:25 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Amani Alonazi, le lun. 14 janv. 2019 20:36:41 +0300, a ecrit:
> I did a benchmark of my node I/O bandwidth and it's 90 MB/s and also
> confirmed
> by StarPU benchmark at the beginning of the execution. Am I missing
> something?
For a spinning disk that would be not too surprising. Since your latency
is 30ms-ish, it looks like a spinning disk.
You could compare with the standard hdparm benchmark:
sudo hdparm -t /dev/sda
(replace sda with however your disk is called)
On one of our servers I'm getting 80MB/s. On my laptop with an nvme disk
I get a whopping 4500MB/s, it really depends on the hardware :)
Samuel
- [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 15/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 17/01/2019
