Archives de la liste
- From: Marion Gevers <marion.gevers AT optusnet.com.au>
- To: typographie AT listes.irisa.fr
- Subject: Re: [typo] Guillemets intempestifs
- Date: Thu, 7 May 2020 18:17:51 +1000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=marion.gevers AT optusnet.com.au; spf=Pass smtp.mailfrom=marion.gevers AT optusnet.com.au; spf=Pass smtp.helo=postmaster AT mail104.syd.optusnet.com.au
- Ironport-phdr: 9a23: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
On 7/05/2020 5:41 pm, Jacques Melot
intempestifs
Le 7/05/20, à 10:55 +1000, nous recevions de Marion
Gevers :
Donc, si je vous comprends bien, vous justifiez l'usage de guillemets pour marquer une insistance. C'est l'usage contre lequel je m'insurge. On peut utiliser le gras ou l'italique à cet effet. Comme le dit Flora, l'usage des guillemets dans ce cas-ci ne se justifierait que pour amoindrir la force du mot entre guillemets.
[J. M.] Pour comprendre le sens de ces guillemets,
j'ai fait une recherche sur l'internet avec les mots clés
élus 174 abstention "massive"
et j'ai regardé la première occurrence ayant vu au premier
coup d'oeil que la phrase que vous citez s'y trouvait. Puis je
me suis
aperçu qu'il ne s'agissait pas d'une page d'accueil du
Huffington
Post, mais de Sud-Ouest. En fait quantité de journaux en ligne,
dont
Médiapart, ont repris cette phrase sous une forme identique.
En réalité, il est difficile de déterminer
avec certitude la valeur de ces guillemets, car il manque le
contexte
dans lequel elle a été rédigée. Ce peut être : avec une
abstention « massive » [guill. = si l'on peut dire] des
élus LR. Mais ce peut aussi être une citation, mais l'absence de
contexte nous empêche d'en décider.
Toujours sur la page de Sud-Ouest, on trouve
ailleurs ce « massive » appliqué à l'abstention,
mais cette fois sans guillemets. Enfin, les guillemets sont
utilisés
un peu partout, clairement pour rapporter des propos.
Comme le texte en question est repris partout sans
aucune modification (donc avec les guillemets sur lesquels on
s'interroge ici), il vient à l'esprit qu'il peut provenir de
l'A.F.P., ce que confirme :
http://www.groupe-alpha.com/fr/toute-actu/depeches-afp/deconfinement-senat-valide-pas-plan-gouvernement,5437.html
qui donne le contexte complet.
À mes yeux ce « massive » a
clairement le sens de : massive si on veut. Les guillemets
utilisés
ont donc, d'une manière ou d'une autre, un rôle d'atténuation.
Ils peuvent aussi servir à relativiser un propos, montrant qu'on
ne
partage pas un point de vue, sans pour autant être
nécessairement
du point de vue opposé.
J. M.
Merci beaucoup pour avoir pris la peine de rechercher l'origine de
cette phrase, et le sens qu'a voulu donner l'auteur à ce
« massive ». Je pense que ce dernier aurait gagné à être plus
explicite !Marion
On 6/05/2020 7:08 pm, diconoma wrote:
Bonjour !
Le Sénat, à majorité de droite, n¹a pas validé ce lundi 4 mai la stratégie de déconfinement du gouvernement à 89 voix contre 81 et 174 abstentions, avec une abstention ³massive² des élus LR et un vote contre des groupes socialiste et communiste.
En anglais, ces guillemets pour mettre l'accent sur un mot m'irritent déjà pas mal depuis longtemps.
? Pour mettre l¹accent sur un terme, vous disposez aussi des guillemets français simples |Alt·0139| et |Alt·0155| espacés, signes élégants et discrets qui différencient « citation » et Ð insistance ð.
La liste Typo — discussions typographiques Les archives : https://sympa.inria.fr/sympa/arc/typographie Désabonnement : <mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
- [typo] Guillemets intempestifs, Marion Gevers, 06/05/2020
- Re: [typo] Guillemets intempestifs, Flora Vern, 06/05/2020
- Re: [typo] Guillemets intempestifs, Jacques Melot, 06/05/2020
- Re: [typo] Guillemets intempestifs, Jacques ANDRÉ, 06/05/2020
- RE: [typo] Guillemets intempestifs, diconoma, 06/05/2020
- Re: [typo] Guillemets intempestifs, Marion Gevers, 07/05/2020
- Re: [typo] Guillemets intempestifs, Jacques Melot, 07/05/2020
- Re: [typo] Guillemets intempestifs, ArDomenach, 06/05/2020
- Re: [typo] Guillemets intempestifs, Thierry Bouche, 06/05/2020
- <Suite(s) possible(s)>
- Re: [typo] Guillemets intempestifs, jtombeur, 06/05/2020
- Re: [typo] Guillemets intempestifs, Philippe Jallon, 06/05/2020
Archives gérées par MHonArc 2.6.18.
