cgal-discuss - CGAL 3.2.1 and g++ 3.3.5
  • To:
  • Subject: CGAL 3.2.1 and g++ 3.3.5
  • Date: Tue, 20 Feb 2007 09:37:08 +0100
  • Organization: Archivideo
Hello all,
I'm upgrading my program from CGAL 3.1 to 3.2.1 and I have found that the example program Triangulation_2/constrained_plus.C doesn't compile. The compiler doesn't give any error nor warning, it just run and run and run...
constrained_plus.C uses Exact_predicates_exact_constructions_kernel, and it is the only one program (in Triangulation_2 examples). This is a problem, because my program uses Exact_predicates_exact_constructions_kernel, and then doesn't compile.
CGAL installation was fine, GMP, GMPXX and MPFR were detected and supported. I'm on a debian sarge amd64 computer. I've looked in the install.log and see some errors but I don't know what I can do to resolve these errors (I've attached the install.log file)
Does anybody has the same error ? Any advices ?
Thanks,
Johan.
Johan Nouvel, Ingénieur R&D
http://www.archivideo.com
tel : +33 (0)2 99 86 30 20
ARCHIVIDEO, 40 rue des Veyettes, 35000 RENNES, FRANCE
log of ./install_cgal
called by jnouvel on mar fév 20 09:11:11 CET 2007
CGAL_DIR is /raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1
This is install_cgal version 31254.
Parsing support specfiles for 3rd party libraries:
BOOST
BOOSTPROGRAMOPTIONS
X11
GMP
GMPXX
MPFR
CORE
CGALCORE
ZLIB
ZLIBMS
LEDA
LEDAWIN
LEDAMS
LEDAWINMS
QT3MT
QT3ST
QT3MSMT
QT3MSST
TAUCSSOLARISCC
TAUCSWINMKL
TAUCSWINATLAS
TAUCSGCCATLAS
TAUCSGCCATLAS2
TAUCSINTELCCATLAS
TAUCSINTELCCMUMPS
TAUCSDARWIN
TAUCSGCCMKL
TAUCSIRIXCC32
TAUCSIRIXCC64
CGAL version is 3.2.1.
basename is /usr/bin/basename.
dirname is /usr/bin/dirname.
uname is /bin/uname.
printf is /usr/bin/printf.
cat is /bin/cat.
cp is /bin/cp.
mv is /bin/mv.
rm is /bin/rm.
ln is /bin/ln.
ls is /bin/ls.
chmod is /bin/chmod.
mkdir is /bin/mkdir.
sed is /bin/sed.
tr is /usr/bin/tr.
awk is /usr/bin/awk.
tee is /usr/bin/tee.
find is /usr/bin/find.
tar is /bin/tar.
sed respects newline.
less is /usr/bin/less.
WARNING: Directory /raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/config/install does not exist, it will be created.
use _let_expr() for evaluating arithmetic expressions.
tput is /usr/bin/tput.
OS is x86-64_Linux-2.6.
g++ is /usr/bin/g++.
gcc is /usr/bin/gcc.
Compiler version test compiled.
Found compiler GNU 3.3.5.
Choosing GNU 3.3.5 as compiler.
WARNING: cannot find file /raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/config/install/x86-64_Linux-2.6_g++-3.3.5.
WARNING: Directory /raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/lib/x86-64_Linux-2.6_g++-3.3.5 does not exist, it will be created.
WARNING: Directory /raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5 does not exist, it will be created.
WARNING: Directory /raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5/CGAL does not exist, it will be created.
Running configuration tests...
    CCTYPE_MACRO_BUG test compiled.
    CCTYPE_MACRO_BUG test linking succeeded.
    CCTYPE_MACRO_BUG test execution succeeded.
    remark: COMMA_BUG test did not compile.
    vvvvvvvvvvvv compiler messages below vvvvvvvvvvvv
    Compiler call:
    /usr/bin/g++  -Wall -I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5    -c './tmp_test.C'
    Got the following error messages:
    tmp_test.C: Dans constructor « A::A(int) »:
    tmp_test.C:40: error: erreur d'analyse syntaxique before `;' token
    ^^^^^^^^^^^^ compiler messages above ^^^^^^^^^^^^
    CONVERSION_OPERATOR_BUG test compiled.
    CONVERSION_OPERATOR_BUG test linking succeeded.
    CONVERSION_OPERATOR_BUG test execution succeeded.
    DEEP_DEPENDENT_TEMPLATE_BUG test compiled.
    DEEP_DEPENDENT_TEMPLATE_BUG test linking succeeded.
    DEEP_DEPENDENT_TEMPLATE_BUG test execution succeeded.
    DENORMALS_COMPILE_BUG test compiled.
    DENORMALS_COMPILE_BUG test linking succeeded.
    DENORMALS_COMPILE_BUG test execution succeeded.
    IEEE_754_BUG test compiled.
    IEEE_754_BUG test linking succeeded.
    IEEE_754_BUG test execution succeeded.
    LONGNAME_BUG test compiled.
    LONGNAME_BUG test linking succeeded.
    LONGNAME_BUG test execution succeeded.
    MATCHING_BUG_3 test compiled.
    MATCHING_BUG_3 test linking succeeded.
    MATCHING_BUG_3 test execution succeeded.
    MATCHING_BUG_4 test compiled.
    MATCHING_BUG_4 test linking succeeded.
    MATCHING_BUG_4 test execution succeeded.
    remark: MATCHING_BUG_5 test did not compile.
    Compiler call:
    tmp_test.C: Dans function « int main() »:
    tmp_test.C:47: error: call of overloaded `enum_cast(A<double>&)' is ambiguous
    tmp_test.C:39: error: candidates are: T enum_cast(const U&) [with T = int, U =
       A<double>]
    tmp_test.C:42: error:                 T enum_cast(const A<U>&) [with T = int, U
       = double]
    MATCHING_BUG_6 test compiled.
    MATCHING_BUG_6 test linking succeeded.
    MATCHING_BUG_6 test execution succeeded.
    MISSING_TEMPLATE_VECTOR_CONSTRUCTORS_BUG test compiled.
    MISSING_TEMPLATE_VECTOR_CONSTRUCTORS_BUG test linking succeeded.
    MISSING_TEMPLATE_VECTOR_CONSTRUCTORS_BUG test execution succeeded.
    NESTED_CLASS_FRIEND_DECLARATION_BUG test compiled.
    NESTED_CLASS_FRIEND_DECLARATION_BUG test linking succeeded.
    NESTED_CLASS_FRIEND_DECLARATION_BUG test execution succeeded.
    NET2003_MATCHING_BUG test compiled.
    NET2003_MATCHING_BUG test linking succeeded.
    NET2003_MATCHING_BUG test execution succeeded.
    AUTOMATIC_TEMPLATE_INCLUSION test compiled.
    remark: AUTOMATIC_TEMPLATE_INCLUSION test linking failed.
    vvvvvvvvvvvv linker/runtime messages below vvvvvvvvvvvv
    Linker call:
    /usr/bin/g++ -o ./tmp_test ./tmp_test.o       -lm
    ./tmp_test.o(.text+0x19): In function `main':
    : undefined reference to `A<float>::square(float const&)'
    collect2: ld a retourné 1 code d'état d'exécution
    ^^^^^^^^^^^^ linker/runtime messages above ^^^^^^^^^^^^
    BIG_ENDIAN test compiled.
    BIG_ENDIAN test linking succeeded.
    remark: BIG_ENDIAN test execution failed.
    Linker call:
    Run program tmp_test:
    Got the following output:
    KOENIG_LOOKUP test compiled.
    KOENIG_LOOKUP test linking succeeded.
    KOENIG_LOOKUP test execution succeeded.
    LIMITS test compiled.
    LIMITS test linking succeeded.
    LIMITS test execution succeeded.
    LOCALE test compiled.
    LOCALE test linking succeeded.
    LOCALE test execution succeeded.
    LONG_DOUBLE_IO test compiled.
    LONG_DOUBLE_IO test linking succeeded.
    LONG_DOUBLE_IO test execution succeeded.
    LONG_LONG test compiled.
    LONG_LONG test linking succeeded.
    LONG_LONG test execution succeeded.
    STDC_NAMESPACE test compiled.
    STDC_NAMESPACE test linking succeeded.
    STDC_NAMESPACE test execution succeeded.
    STL test compiled.
    STL test linking succeeded.
    STL test execution succeeded.
    TMPL_IN_TMPL_DEPENDING_FUNCTION_PARAM test compiled.
    TMPL_IN_TMPL_DEPENDING_FUNCTION_PARAM test linking succeeded.
    TMPL_IN_TMPL_DEPENDING_FUNCTION_PARAM test execution succeeded.
    TMPL_IN_TMPL_PARAM test compiled.
    TMPL_IN_TMPL_PARAM test linking succeeded.
    TMPL_IN_TMPL_PARAM test execution succeeded.
    remark: TWO_STAGE_NAME_LOOKUP test did not compile.
    Compiler call:
    tmp_test.C: Dans function « void A::f(const T&) [with T = int] »:
    tmp_test.C:54:   instantiated from here
    tmp_test.C:45: error: aggregate value used where an integer was expected
    NUMERIC_LIMITS_BUG test compiled.
    NUMERIC_LIMITS_BUG test linking succeeded.
    NUMERIC_LIMITS_BUG test execution succeeded.
    OUTOFLINE_MEMBER_DEFINITION_BUG test compiled.
    OUTOFLINE_MEMBER_DEFINITION_BUG test linking succeeded.
    OUTOFLINE_MEMBER_DEFINITION_BUG test execution succeeded.
    OUTOFLINE_TEMPLATE_MEMBER_DEFINITION_BUG_2 test compiled.
    OUTOFLINE_TEMPLATE_MEMBER_DEFINITION_BUG_2 test linking succeeded.
    OUTOFLINE_TEMPLATE_MEMBER_DEFINITION_BUG_2 test execution succeeded.
    OUTOFLINE_TEMPLATE_MEMBER_DEFINITION_BUG test compiled.
    OUTOFLINE_TEMPLATE_MEMBER_DEFINITION_BUG test linking succeeded.
    OUTOFLINE_TEMPLATE_MEMBER_DEFINITION_BUG test execution succeeded.
    SUNPRO_RWSTD test compiled.
    SUNPRO_RWSTD test linking succeeded.
    SUNPRO_RWSTD test execution succeeded.
    TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG test compiled.
    TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG test linking succeeded.
    TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG test execution succeeded.
    USING_BASE_MEMBER_BUG_2 test compiled.
    USING_BASE_MEMBER_BUG_2 test linking succeeded.
    USING_BASE_MEMBER_BUG_2 test execution succeeded.
    USING_BASE_MEMBER_BUG_3 test compiled.
    USING_BASE_MEMBER_BUG_3 test linking succeeded.
    USING_BASE_MEMBER_BUG_3 test execution succeeded.
    USING_BASE_MEMBER_BUG test compiled.
    USING_BASE_MEMBER_BUG test linking succeeded.
    USING_BASE_MEMBER_BUG test execution succeeded.
Trying to autofind 3rd party libraries...
Testing support for BOOST ...
    OK: requirements and incompatibilities.
    Testing with default flags.
    BOOST test compiled.
    BOOST test linking succeeded.
    BOOST test execution succeeded.
OK: BOOST test program.
Testing support for BOOSTPROGRAMOPTIONS ...
    remark: BOOST_PROGRAM_OPTIONS test did not compile.
    Compiler call:
    tmp_test.C:34:37: boost/program_options.hpp : Aucun fichier ou répertoire de ce type
    tmp_test.C: Dans function « int main(int, char**) »:
    tmp_test.C:38: error: `boost' undeclared (first use this function)
    tmp_test.C:38: error: (Each undeclared identifier is reported only once for
       each function it appears in.)
    tmp_test.C:38: error: erreur d'analyse syntaxique before `::' token
    tmp_test.C:39: error: `desc' undeclared (first use this function)
    tmp_test.C:43: error: erreur d'analyse syntaxique before `::' token
    tmp_test.C:47: error: `vm' undeclared (first use this function)
  Looking for BOOST_PROGRAM_OPTIONS in standard locations...
  - Looking for includes in /usr/include/\* ...
Failed: BOOST_PROGRAM_OPTIONS test program.
Testing support for X11 ...
    X11 test compiled.
    remark: X11 test linking failed.
    Linker call:
    /usr/bin/g++ -o ./tmp_test ./tmp_test.o     -lX11     -lm
    /usr/bin/ld: ne peut trouver -lX11
  Looking for X11 in standard locations...
  - Looking for includes in /usr/X11\*/include ...
  - Trying /usr/X11R6/include.
    X11 with include /usr/X11R6/include test compiled.
    Linker call:
  --- Looking for libs in /usr/X11\*/lib64 ...
  --- Looking for libs in /usr/X11\*/lib ...
  ---- Trying /usr/X11R6/lib.
    X11 test linking succeeded.
    X11 test execution succeeded.
  Found X11 with INCL_DIR /usr/X11R6/include and LIB_DIR /usr/X11R6/lib.
OK: X11 test program.
Testing support for GMP ...
    GMP test compiled.
    GMP test linking succeeded.
    GMP test execution succeeded.
OK: GMP test program.
Testing support for GMPXX ...
    GMPXX test compiled.
    GMPXX test linking succeeded.
    GMPXX test execution succeeded.
OK: GMPXX test program.
Testing support for MPFR ...
    MPFR test compiled.
    MPFR test linking succeeded.
    MPFR test execution succeeded.
OK: MPFR test program.
Testing support for CORE ...
    remark: CORE test did not compile.
    Compiler call:
    /usr/bin/g++  -Wall -I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5  -I/usr/X11R6/include   -c './tmp_test.C'
    tmp_test.C:40:23: CORE/CORE.h : Aucun fichier ou répertoire de ce type
    tmp_test.C:45: error: `Expr' undeclared (first use this function)
    tmp_test.C:45: error: (Each undeclared identifier is reported only once for
    tmp_test.C:45: error: erreur d'analyse syntaxique before `=' token
    tmp_test.C:46: error: `x' undeclared (first use this function)
    tmp_test.C:46: error: `y' undeclared (first use this function)
  Looking for CORE in standard locations...
Failed: CORE test program.
Testing support for CGALCORE ...
    CORE (shipped with CGAL) test compiled.
    CORE (shipped with CGAL) test linking succeeded.
    CORE (shipped with CGAL) test execution succeeded.
OK: CORE test program.
Testing support for ZLIB ...
    ZLIB (Unix) test compiled.
    ZLIB (Unix) test linking succeeded.
    ZLIB (Unix) test execution succeeded.
OK: ZLIB test program.
Testing support for ZLIBMS ...
Failed: ZLIBMS requires variable WINDOWS_COMPILER.
Testing support for LEDA ...
    remark: LEDA (Unix) test did not compile.
    Compiler call:
    tmp_test.C:35:24: LEDA/basic.h : Aucun fichier ou répertoire de ce type
    tmp_test.C:36:26: LEDA/integer.h : Aucun fichier ou répertoire de ce type
    tmp_test.C:47:33: LEDA/REDEFINE_NAMES.h : Aucun fichier ou répertoire de ce type
    tmp_test.C:48: error: erreur de syntaxe before `;' token
    tmp_test.C:49:33: LEDA/UNDEFINE_NAMES.h : Aucun fichier ou répertoire de ce type
    tmp_test.C:53: error: `I' undeclared (first use this function)
    tmp_test.C:53: error: (Each undeclared identifier is reported only once for
    tmp_test.C:53: error: erreur d'analyse syntaxique before `(' token
    tmp_test.C:56: error: `a' undeclared (first use this function)
    tmp_test.C:56: error: `b' undeclared (first use this function)
    tmp_test.C:61: error: `__LEDA__' undeclared (first use this function)
  Looking for LEDA (Unix) in standard locations...
Failed: LEDA test program.
Testing support for LEDAWIN ...
Failed: LEDAWIN requires feature LEDA.
Testing support for LEDAMS ...
Failed: LEDAMS requires variable WINDOWS_COMPILER.
Testing support for LEDAWINMS ...
Failed: LEDAWINMS requires feature LEDA.
Testing support for QT3MT ...
    remark: QT (Unix (multi-threaded)) test did not compile.
    Compiler call:
    tmp_test.C:34:21: qglobal.h : Aucun fichier ou répertoire de ce type
    tmp_test.C:35:20: qarray.h : Aucun fichier ou répertoire de ce type
    tmp_test.C:37: error: erreur d'analyse syntaxique before `)' token
    tmp_test.C:40: error: `num' was not declared in this scope
    tmp_test.C:40: error: 'QArray' is used as a type, but is not defined as a type.
    tmp_test.C:42: error: le C++ ISO interdit la déclaration de « f » sans type
    tmp_test.C:42: error: invalid initializer
    tmp_test.C:43: error: erreur d'analyse syntaxique before `for'
    tmp_test.C:43: error: `num' was not declared in this scope
    tmp_test.C:43: error: erreur d'analyse syntaxique before `;' token
    tmp_test.C:43: error: erreur de syntaxe before `++' token
    tmp_test.C:51: error: `QT_VERSION_STR' undeclared (first use this function)
    tmp_test.C:51: error: (Each undeclared identifier is reported only once for
    tmp_test.C:53: error: `QArray' undeclared (first use this function)
    tmp_test.C:53: error: erreur d'analyse syntaxique before `>' token
    tmp_test.C:55: error: `a' undeclared (first use this function)
  Looking for QT (Unix (multi-threaded)) in standard locations...
  - Looking for includes in /usr/include/qt3 ...
  - Looking for includes in /raid/shared/linux/x86_64/opt/qt/4.2.1/include ...
Failed: QT test program.
Testing support for QT3ST ...
    remark: QT (Unix (single-threaded)) test did not compile.
    Compiler call:
  Looking for QT (Unix (single-threaded)) in standard locations...
Testing support for QT3MSMT ...
Failed: QT3MSMT requires variable WINDOWS_COMPILER.
Testing support for QT3MSST ...
Failed: QT3MSST requires variable WINDOWS_COMPILER.
Testing support for TAUCSSOLARISCC ...
    remark: TAUCS (TAUCS for Solaris cc) test did not compile.
    Compiler call:
    tmp_test.C:48:23: taucs.h : Aucun fichier ou répertoire de ce type
    tmp_test.C:60: error: `taucs_ccs_matrix' undeclared (first use this function)
    tmp_test.C:60: error: (Each undeclared identifier is reported only once for
    tmp_test.C:60: error: `pMatrix' undeclared (first use this function)
    tmp_test.C:60: error: `TAUCS_DOUBLE' undeclared (first use this function)
    tmp_test.C:60: error: `taucs_ccs_create' undeclared (first use this function)
    tmp_test.C:68: error: `taucs_dccs_free' undeclared (first use this function)
    tmp_test.C:76: error: `taucs_ccs_order' undeclared (first use this function)
  Looking for TAUCS (TAUCS for Solaris cc) in standard locations...
Failed: TAUCS test program.
Testing support for TAUCSWINMKL ...
    remark: TAUCS (TAUCS for Visual C++/Intel MKL) test did not compile.
    Compiler call:
  Looking for TAUCS (TAUCS for Visual C++/Intel MKL) in standard locations...
Testing support for TAUCSWINATLAS ...
    remark: TAUCS (TAUCS for Visual C++/Atlas) test did not compile.
    Compiler call:
  Looking for TAUCS (TAUCS for Visual C++/Atlas) in standard locations...
Testing support for TAUCSGCCATLAS ...
    remark: TAUCS (TAUCS for gcc/Atlas) test did not compile.
    Compiler call:
  Looking for TAUCS (TAUCS for gcc/Atlas) in standard locations...
Testing support for TAUCSGCCATLAS2 ...
    remark: TAUCS (TAUCS for gcc/Atlas variant) test did not compile.
    Compiler call:
  Looking for TAUCS (TAUCS for gcc/Atlas variant) in standard locations...
Testing support for TAUCSINTELCCATLAS ...
    remark: TAUCS (TAUCS for Linux Intel cc/Atlas) test did not compile.
    Compiler call:
  Looking for TAUCS (TAUCS for Linux Intel cc/Atlas) in standard locations...
Testing support for TAUCSINTELCCMUMPS ...
    remark: TAUCS (TAUCS for Linux Intel cc/MUMPS) test did not compile.
    Compiler call:
  Looking for TAUCS (TAUCS for Linux Intel cc/MUMPS) in standard locations...
Testing support for TAUCSDARWIN ...
    remark: TAUCS (TAUCS for gcc/Darwin) test did not compile.
    Compiler call:
  Looking for TAUCS (TAUCS for gcc/Darwin) in standard locations...
Testing support for TAUCSGCCMKL ...
    remark: TAUCS (TAUCS for gcc/Intel MKL) test did not compile.
    Compiler call:
  Looking for TAUCS (TAUCS for gcc/Intel MKL) in standard locations...
Testing support for TAUCSIRIXCC32 ...
    remark: TAUCS (TAUCS for IRIX cc 32 bits) test did not compile.
    Compiler call:
  Looking for TAUCS (TAUCS for IRIX cc 32 bits) in standard locations...
Testing support for TAUCSIRIXCC64 ...
    remark: TAUCS (TAUCS for IRIX cc 64 bits) test did not compile.
    Compiler call:
  Looking for TAUCS (TAUCS for IRIX cc 64 bits) in standard locations...
BOOST test passed.
X11 test passed.
GMP test passed.
GMPXX test passed.
MPFR test passed.
CGALCORE test passed.
ZLIB test passed.
Settings stored in /raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/config/install/x86-64_Linux-2.6_g++-3.3.5.
remark: makefile_x86-64_Linux-2.6_g++-3.3.5 does not exist,
 creating.
Compilation of libCGAL static x86-64_Linux-2.6_g++-3.3.5 succeeded.
vvvvvvvvvvvv build log for libCGAL static shown below vvvvvvvvvvvv
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c assertions.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Bbox_2_intersections.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Bbox_3_intersections.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c cgal_logo.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Color.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_header_extended_OFF.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_header_OFF.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_scanner_OFF.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_writer_inventor.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_writer_OFF.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_writer_VRML_2.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_writer_wavefront.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Geomview_stream.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Interval_arithmetic.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c io.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c JAMA_numeric_solver.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c KDS_Log.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c kernel.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c MP_Float.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c numeric_solvers_support.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Polynomial.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Random.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Real_timer.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Timer.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Turkowski_numeric_solver.cpp
ar cr ''libCGAL.a \
`ls *.o | awk '{for (i=1; i<=NF;++i){printf "";print $i}}'`\
cat >/dev/null libCGAL.a
rm assertions.o Bbox_2_intersections.o Bbox_3_intersections.o cgal_logo.o Color.o File_header_extended_OFF.o File_header_OFF.o File_scanner_OFF.o File_writer_inventor.o File_writer_OFF.o File_writer_VRML_2.o File_writer_wavefront.o Geomview_stream.o Interval_arithmetic.o io.o JAMA_numeric_solver.o KDS_Log.o kernel.o MP_Float.o numeric_solvers_support.o Polynomial.o Random.o Real_timer.o Timer.o Turkowski_numeric_solver.o
mv libCGAL.a '/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/lib/x86-64_Linux-2.6_g++-3.3.5'
^^^^^^^^^^^^ build log for libCGAL static shown above ^^^^^^^^^^^^
Compilation of libCGAL shared x86-64_Linux-2.6_g++-3.3.5 succeeded.
vvvvvvvvvvvv build log for libCGAL shared shown below vvvvvvvvvvvv
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c assertions.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Bbox_2_intersections.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Bbox_3_intersections.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c cgal_logo.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Color.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_header_extended_OFF.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_header_OFF.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_scanner_OFF.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_writer_inventor.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_writer_OFF.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_writer_VRML_2.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c File_writer_wavefront.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Geomview_stream.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Interval_arithmetic.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c io.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c JAMA_numeric_solver.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c KDS_Log.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c kernel.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c MP_Float.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c numeric_solvers_support.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Polynomial.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Random.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Real_timer.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Timer.cpp
/usr/bin/g++  -fpic -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE   -c Turkowski_numeric_solver.cpp
/usr/bin/g++ -shared  -o ''libCGAL.so \
mv libCGAL.so ''/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/lib/x86-64_Linux-2.6_g++-3.3.5''
^^^^^^^^^^^^ build log for libCGAL shared shown above ^^^^^^^^^^^^
Compilation of libCore static x86-64_Linux-2.6_g++-3.3.5 succeeded.
vvvvvvvvvvvv build log for libCore static shown below vvvvvvvvvvvv
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE  -c CoreAux.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE  -c extLong.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE  -c CoreDefs.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE  -c CoreIO.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE  -c BigFloat.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE  -c Real.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE  -c Expr.cpp
/usr/bin/g++  -O2 -Wall  '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.3.5' '-I/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/include'  -I/usr/X11R6/include            -DCGAL_USE_CGAL_CORE  -c GmpIO.cpp
ar cr ''libcore++.a \
cat >/dev/null libcore++.a
rm CoreAux.o extLong.o CoreDefs.o CoreIO.o BigFloat.o Real.o Expr.o GmpIO.o
mv libcore++.a '/raid/shared/src/CGAL/CGAL-3.2.1/CGAL-3.2.1/lib/x86-64_Linux-2.6_g++-3.3.5'
^^^^^^^^^^^^ build log for libCore static shown above ^^^^^^^^^^^^
