- To:
- Subject: Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5
- Date: Thu, 22 Feb 2007 16:46:05 +0100
- Organization: MPI Saarbruecken
Hi!
Interesting option! I did not know this before ...
Andreas
On Thursday 22 February 2007 15:21, Laurent Rineau wrote:
> On Thursday 22 February 2007 15:01:30 Joachim Reichel wrote:
> > Hi,
> > > If you need CGAL-3.2, you could compile a recent gcc yourself.
> > I wanted to propose the same, but Laurent was faster ;-)
> > Note that the C++ ABI has changed in g++ 3.4. Hence you also need to
> > compile Boost, GMP and MPFR yourself.
> No. Use "-fabi-version=1". :-)
> Quoted from the manual:
> " -fabi-version=n
> Use version n of the C++ ABI. Version 2 is the version of the C++
> ABI that first appeared in G++ 3.4. Version 1 is the version of the C++
> ABI that first appeared in G++ 3.2. Version 0 will always be the version
> that conforms most closely to the C++ ABI specification. Therefore, the
> ABI obtained using version 0 will change as ABI bugs are fixed.
> The default is version 2."
> Laurent Rineau
> INRIA - Sophia Antipolis
> BP 93, 2004 Route des Lucioles
> 06902 Sophia Antipolis Cedex FRANCE
> Phone: +33 4 92 38 71 54
- CGAL 3.2.1 and g++ 3.3.5, Johan Nouvel, 02/20/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/20/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Johan Nouvel, 02/21/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/21/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Johan Nouvel, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Laurent Rineau, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Andreas Meyer, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Andreas Fabri, 02/20/2007
