cgal-discuss - Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5
  • To:
  • Subject: Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5
  • Date: Wed, 21 Feb 2007 10:08:47 +0100
  • Organization: Archivideo
Hello Joachim,
I've done the same thing (compile CGAL3.2.1 sources and Triangulation_2/constrained_plus.C) on a i386 and it works. It seems to be an amd64 specific problem.
I use only Debian packages, same version on i386 and amd64 :
gcc : version 1:3.3.5-13 (gcc-3.3_3.3.5-13_i386.deb and
gcc-3.3_3.3.5-13_amd64.deb)
gmp : version 4.1.4-6 (libgmp3_4.1.4-6_i386.deb and
libgmp3_4.1.4-6_amd64.deb)
mpfr : version 2.1.1-5 (libmpfr-dev_2.1.1-5_i386.deb and
libmpfr-dev_2.1.1-5_amd64.deb)
I'll keep the CGAL3.1 alive for now, so I could wait some times before
switching.
Regards,
Johan.
Joachim Reichel wrote:
Hi Johan,
CGAL provides packages for Debian sarge. When I created the packages, I
also tested demos and examples and did not notice any problems, though I
tested on i386 only. I could test it on amd64 again, but that has to
wait until the end of the week.
Do you use the Debian packages for gcc, GMP, and MPFR? Which versions?
(Debian package version number (if applicable), upstream version number
otherwise).
Errors in install.log are not directly a problem. install_cgal does many
tests to detect compiler characteristics and supported libraries, so
some tests will fail. If the output (stdout) of install_cgal is fine,
you probably do not need to look at install.log.
Regards,
Joachim
Johan Nouvel, Ingénieur R&D
http://www.archivideo.com
tel : +33 (0)2 99 86 30 20
ARCHIVIDEO, 40 rue des Veyettes, 35000 RENNES, FRANCE
