cgal-discuss - Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5
  • To:
  • Subject: Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5
  • Date: Wed, 21 Feb 2007 23:48:28 +0100
Hi Johan,
> I've done the same thing (compile CGAL3.2.1 sources and
> Triangulation_2/constrained_plus.C) on a i386 and it works. It seems to
> be an amd64 specific problem.
yes, I can reproduce the problem. The 3.3 development branch of gcc has
been closed long ago, so even if one could create a small test case, it
is unlikely that this bug gets fixed. Can you use a more up-to-date
compiler? It works without problems with g++ 4.1 on Debian etch/sid.
Regards,
Joachim
