- To:
- Subject: Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5
- Date: Thu, 22 Feb 2007 15:21:54 +0100
- Organization: Inria, Sophia Antipolis, FRANCE
On Thursday 22 February 2007 15:01:30 Joachim Reichel wrote:
> Hi,
> > If you need CGAL-3.2, you could compile a recent gcc yourself.
> I wanted to propose the same, but Laurent was faster ;-)
> Note that the C++ ABI has changed in g++ 3.4. Hence you also need to
> compile Boost, GMP and MPFR yourself.
No. Use "-fabi-version=1". :-)
Quoted from the manual:
" -fabi-version=n
Use version n of the C++ ABI. Version 2 is the version of the C++ ABI
that first appeared in G++ 3.4. Version 1 is the version of the C++ ABI that
first appeared in G++ 3.2. Version 0 will always be the version that
conforms most closely to the C++ ABI specification. Therefore, the ABI
obtained using version 0 will change as ABI bugs are fixed.
The default is version 2."
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Phone: +33 4 92 38 71 54
- CGAL 3.2.1 and g++ 3.3.5, Johan Nouvel, 02/20/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/20/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Johan Nouvel, 02/21/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/21/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Johan Nouvel, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Laurent Rineau, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Andreas Meyer, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Andreas Fabri, 02/20/2007
