- To:
- Subject: Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5
- Date: Tue, 20 Feb 2007 11:06:20 +0100
Johan Nouvel wrote:
Hello all,
I'm upgrading my program from CGAL 3.1 to 3.2.1 and I have found that the example program Triangulation_2/constrained_plus.C doesn't compile. The compiler doesn't give any error nor warning, it just run and run and run...
constrained_plus.C uses Exact_predicates_exact_constructions_kernel, and it is the only one program (in Triangulation_2 examples). This is a problem, because my program uses Exact_predicates_exact_constructions_kernel, and then doesn't compile.
Hello Johan,
Is it a typo that you write two times
Exact_predicates_exact_constructions_kernel ??
If you change the kernel you also might have to change the exact tag
best regards,
andreas
CGAL installation was fine, GMP, GMPXX and MPFR were detected and supported. I'm on a debian sarge amd64 computer. I've looked in the install.log and see some errors but I don't know what I can do to resolve these errors (I've attached the install.log file)
Does anybody has the same error ? Any advices ?
Thanks,
Johan.
- CGAL 3.2.1 and g++ 3.3.5, Johan Nouvel, 02/20/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/20/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Johan Nouvel, 02/21/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/21/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Johan Nouvel, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Laurent Rineau, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Andreas Meyer, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Andreas Fabri, 02/20/2007
