- To:
- Subject: Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5
- Date: Wed, 21 Feb 2007 10:37:19 +0100
- Organization: Archivideo
Hello Andreas,
No, it isn't a typo, constrained_plus.C and my program use Exact_predicates_exact_constructions_kernel, with the right intersection tag.
Robustness is the goal, even if it takes more time than Exact_predicates_inexact_constructions_kernel. That's why I need this kernel. It works on i386 but many of our computers are amd64.
Regards,
Johan.
Andreas Fabri wrote:
Johan Nouvel wrote:
Hello all,
I'm upgrading my program from CGAL 3.1 to 3.2.1 and I have found that the example program Triangulation_2/constrained_plus.C doesn't compile. The compiler doesn't give any error nor warning, it just run and run and run...
constrained_plus.C uses Exact_predicates_exact_constructions_kernel, and it is the only one program (in Triangulation_2 examples). This is a problem, because my program uses Exact_predicates_exact_constructions_kernel, and then doesn't compile.
Hello Johan,
Is it a typo that you write two times Exact_predicates_exact_constructions_kernel ??
If you change the kernel you also might have to change the exact tag
best regards,
andreas
Johan Nouvel, Ingénieur R&D
http://www.archivideo.com
tel : +33 (0)2 99 86 30 20
ARCHIVIDEO, 40 rue des Veyettes, 35000 RENNES, FRANCE
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, (continued)
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/20/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Johan Nouvel, 02/21/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/21/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Johan Nouvel, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Laurent Rineau, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Joachim Reichel, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Andreas Meyer, 02/22/2007
- Re: [cgal-discuss] CGAL 3.2.1 and g++ 3.3.5, Andreas Fabri, 02/20/2007
