- To:
- Subject: Nef Polyhedra test cases
- Date: Sun, 6 Jan 2008 23:36:28 -0600
- Domainkey-signature: s=main; d=mail.utexas.edu; c=nofws; q=dns; h=Received:Received:Received:Mime-Version: Content-Transfer-Encoding:Message-Id:Content-Type:To: From:Subject:Date:X-Mailer; b=uwv2UpGecXJOR1/4G7pwV0av1FN++1816XWkOVE73z5wCdx618MXf r0bAjFZJEZzC3UQ19J7YsacvQT5JkNv7ccljaYNSlu9wNMob73na5 3tAE9BEpCGru82FJIn4dZ6D+ReCihiAfhSBWXMz6qobXhwim20jI9 ja1bTGkUQEXk=;
Hi,
I'm having an awful lot of trouble successfully building Nef Polyhedra from .off input files. The only model I have successfully translated from .off to a Nef Polyhedron and back is a cube. I have tried a number of different models, all supposed to be watertight, and which were certified by the Polyhedron_3::is_closed() function. It certainly may be the case that there was something off (ba dum chh) about these models, but I've reached my point of frustration. If anyone has any known working examples of importing models into the Nef Polyhedron type, or any suggestions, I would much appreciate the tips.
-- Gilbert Bernstein
- Nef Polyhedra test cases, Gilbert Bernstein, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, LoadCom, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Andreas Fabri, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Gilbert Bernstein, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Peter Hachenberger, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Peter Hachenberger, 01/08/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Gilbert Bernstein, 01/09/2008
