cgal-discuss - Re: [cgal-discuss] Nef Polyhedra test cases
  • To:
  • Subject: Re: [cgal-discuss] Nef Polyhedra test cases
  • Date: Mon, 7 Jan 2008 03:57:03 -0600
  • Domainkey-signature: s=main; d=mail.utexas.edu; c=nofws; q=dns; h=Received:Received:Received:Mime-Version:In-Reply-To: References:Content-Type:Message-Id: Content-Transfer-Encoding:From:Subject:Date:To: X-Mailer; b=F84foqFK+WCfx9hDd40E94ND3CB38+2D4E/b6dhpMVY6nL92Nwicm wSt2qVUNBsQxEcl2qwgykLn4Na798r2MHKjqBgYJZoAgGAn6BGpDf OmPj4PuNS9BMZlBU+KV1gErZJT0jKAXuSmgbsWrKRsO65zIfgDxjM M0RAZh0od/Hw=;
Andreas,
I just realized I didn't answer your question. I'm sorry. In case you or any one else was wondering, I was using the example program "handling double coordinates".
Thank you for your help and patience,
-- Gilbert
On Jan 7, 2008, at 3:47 AM, Gilbert Bernstein wrote:
It seems I have to apologize for making such a stink here. It was probably a false alarm.
I think I had unreasonable expectations on the speed of the computation and thought the program had gone into a loop. I managed to push a smaller model (3756 vertices 7512 triangles) through the conversion both ways just now by waiting about half an hour. I also know the model in question has some very funky joins between parts (lots of long, close, sharp polygons) so I'm pretty sure this was just a matter of patience. If only I was testing with the teapot. Then I could make a really awful joke about watched teapots.
I just ran another model (1007 vert 2010 tri) through just fine, much faster, so yeah...
-- Gilbert
On Jan 7, 2008, at 3:12 AM, Andreas Fabri wrote:
Gilbert,
It might be the best to just post a file that makes problems.
What is your OS/compiler, did you just take the example or
demo program, or write your own program? In the latter case
what kernel did you chooses?
andreas
Andreas,
I'm fairly sure all of the meshes I've tried are triangular meshes, (I went back and checked a couple of them (since they're in ascii) by eye) so I don't think that's the problem.
-- Gilbert
On Jan 7, 2008, at 2:10 AM, Andreas Fabri wrote:
Hello,
A typical problem is to have faces which are not triangular,
and at the same time not coplanar.
andreas
Hi,
I'm having an awful lot of trouble successfully building Nef Polyhedra from .off input files. The only model I have successfully translated from .off to a Nef Polyhedron and back is a cube. I have tried a number of different models, all supposed to be watertight, and which were certified by the Polyhedron_3::is_closed() function. It certainly may be the case that there was something off (ba dum chh) about these models, but I've reached my point of frustration. If anyone has any known working examples of importing models into the Nef Polyhedron type, or any suggestions, I would much appreciate the tips.
-- Gilbert Bernstein
