- To:
- Subject: Re: [cgal-discuss] Nef Polyhedra test cases
- Date: Mon, 7 Jan 2008 03:47:48 -0600
- Domainkey-signature: s=main; d=mail.utexas.edu; c=nofws; q=dns; h=Received:Received:Received:Mime-Version:In-Reply-To: References:Content-Type:Message-Id: Content-Transfer-Encoding:From:Subject:Date:To: X-Mailer; b=sve3L3pJUvettL7swYPk+kr4DXAETfhgCkVaeSbBeEaaJWjv6B9lb 5m/QmKw1PHQPo6C8SD/9ciFvHaG4zlTRuolRVA7z8vm6RFijsRKV1 cNDF2c+R9Qxd+uKGpcXjNCUf+ufaR2Q4jcZpUQ8INKPgLD6j8Tgui d+NVc7k8p6JU=;
It seems I have to apologize for making such a stink here. It was probably a false alarm.
I think I had unreasonable expectations on the speed of the computation and thought the program had gone into a loop. I managed to push a smaller model (3756 vertices 7512 triangles) through the conversion both ways just now by waiting about half an hour. I also know the model in question has some very funky joins between parts (lots of long, close, sharp polygons) so I'm pretty sure this was just a matter of patience. If only I was testing with the teapot. Then I could make a really awful joke about watched teapots.
I just ran another model (1007 vert 2010 tri) through just fine, much faster, so yeah...
-- Gilbert
On Jan 7, 2008, at 3:12 AM, Andreas Fabri wrote:
Gilbert,
It might be the best to just post a file that makes problems.
What is your OS/compiler, did you just take the example or
demo program, or write your own program? In the latter case
what kernel did you chooses?
andreas
Gilbert Bernstein wrote:
Andreas,--
I'm fairly sure all of the meshes I've tried are triangular meshes, (I went back and checked a couple of them (since they're in ascii) by eye) so I don't think that's the problem.
-- Gilbert
On Jan 7, 2008, at 2:10 AM, Andreas Fabri wrote:
Hello,
A typical problem is to have faces which are not triangular,
and at the same time not coplanar.
andreas
Hi,
I'm having an awful lot of trouble successfully building Nef Polyhedra from .off input files. The only model I have successfully translated from .off to a Nef Polyhedron and back is a cube. I have tried a number of different models, all supposed to be watertight, and which were certified by the Polyhedron_3::is_closed() function. It certainly may be the case that there was something off (ba dum chh) about these models, but I've reached my point of frustration. If anyone has any known working examples of importing models into the Nef Polyhedron type, or any suggestions, I would much appreciate the tips.
-- Gilbert Bernstein
- Nef Polyhedra test cases, Gilbert Bernstein, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, LoadCom, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Andreas Fabri, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Gilbert Bernstein, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Peter Hachenberger, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Peter Hachenberger, 01/08/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Gilbert Bernstein, 01/09/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Peter Hachenberger, 01/09/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Gilbert Bernstein, 01/20/2008
