- To:
- Subject: Re: [cgal-discuss] Nef Polyhedra test cases
- Date: Mon, 7 Jan 2008 03:07:18 -0600
- Domainkey-signature: s=main; d=mail.utexas.edu; c=nofws; q=dns; h=Received:Received:Received:Mime-Version:In-Reply-To: References:Content-Type:Message-Id: Content-Transfer-Encoding:From:Subject:Date:To: X-Mailer; b=xWRVffTZ150l3cwE7QCFv5AZNv8QO8SO2vx+/fcTcGSopMhTP5OUN IyG/7zJB9+XZmWOWTf7r6tVD8BwCNKMe3572DM5VqSeB2rsKNUvSM fsJ7neNRAmjnvdNAjjZh5Ami23Yh1GGHTKlD7hbbT4T42huEMDbzS YzqXoxgeCb24=;
Andreas,
I'm fairly sure all of the meshes I've tried are triangular meshes, (I went back and checked a couple of them (since they're in ascii) by eye) so I don't think that's the problem.
-- Gilbert
On Jan 7, 2008, at 2:10 AM, Andreas Fabri wrote:
Hello,
A typical problem is to have faces which are not triangular,
and at the same time not coplanar.
andreas
Gilbert Bernstein wrote:
Hi,--
I'm having an awful lot of trouble successfully building Nef Polyhedra from .off input files. The only model I have successfully translated from .off to a Nef Polyhedron and back is a cube. I have tried a number of different models, all supposed to be watertight, and which were certified by the Polyhedron_3::is_closed() function. It certainly may be the case that there was something off (ba dum chh) about these models, but I've reached my point of frustration. If anyone has any known working examples of importing models into the Nef Polyhedron type, or any suggestions, I would much appreciate the tips.
-- Gilbert Bernstein
- Nef Polyhedra test cases, Gilbert Bernstein, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, LoadCom, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Andreas Fabri, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Gilbert Bernstein, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Peter Hachenberger, 01/07/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Peter Hachenberger, 01/08/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Gilbert Bernstein, 01/09/2008
- Re: [cgal-discuss] Nef Polyhedra test cases, Peter Hachenberger, 01/09/2008
