cgal-discuss - Re: [cgal-discuss] Nef Polyhedra test cases
  • To:
  • Subject: Re: [cgal-discuss] Nef Polyhedra test cases
  • Date: Mon, 07 Jan 2008 10:12:19 +0100
Gilbert,
It might be the best to just post a file that makes problems.
What is your OS/compiler, did you just take the example or
demo program, or write your own program? In the latter case
what kernel did you chooses?
andreas
Gilbert Bernstein wrote:
Andreas,
I'm fairly sure all of the meshes I've tried are triangular meshes, (I went back and checked a couple of them (since they're in ascii) by eye) so I don't think that's the problem.
-- Gilbert
On Jan 7, 2008, at 2:10 AM, Andreas Fabri wrote:
Hello,
A typical problem is to have faces which are not triangular,
and at the same time not coplanar.
andreas
Hi,
I'm having an awful lot of trouble successfully building Nef Polyhedra from .off input files. The only model I have successfully translated from .off to a Nef Polyhedron and back is a cube. I have tried a number of different models, all supposed to be watertight, and which were certified by the Polyhedron_3::is_closed() function. It certainly may be the case that there was something off (ba dum chh) about these models, but I've reached my point of frustration. If anyone has any known working examples of importing models into the Nef Polyhedron type, or any suggestions, I would much appreciate the tips.
-- Gilbert Bernstein
